Chevrolet Captiva 2,2D AWD: Check Engine Light On Despite Normal Engine Performance
mariosiwy 5937 4
  • #1 16313088
    mariosiwy
    Rate: 17
    Hello, the check engine light is on in my captivi. The ASO stated that it was a throttle, but the engine was running normally at idle and the same on the road. I drove to the Opel for confirmation and they showed throttle and manifold errors. I read on the net that someone had similar problems and replaced the throttles, collector, lambda and the problem has not disappeared.
    I am asking for help from Dear Colleagues.
  • #2 16313101
    Pawel wawa
    Help: 1262
    Rate: 4429
    I'm not sure what you expect from us? Should we fix the car for you? Say don't worry, just press the gas pedal six times? I omit that you did not provide any errors. Car to the workshop, repair order and you need to remove the defect upon receipt.
  • #3 16313129
    mariosiwy
    Rate: 17
    You picked me up badly Chevrolet, the hustlers two months ago wanted to pull me on a 3000,000 turbine. A friend repaired it for me for the proverbial flask fault - a safety belt. Today I read about a similar case and the Chevrolet guy replaced 3 elements and the indicator light still comes on.
    So, are you suggesting that I follow him?
    I am looking for help if anyone has had a similar case or knows the reason.
  • #4 16313136
    Pawel wawa
    Help: 1262
    Rate: 4429
    Everything is nice, but how do we know, you need at least the exact number of errors, it would be great to describe them. Then you can think about something.
  • #5 16504432
    markus49
    Probably the topic is no longer relevant, but maybe I'm wrong ;)
    I had a similar problem, first the error on the throttle, then on the injection. The indicator light came on after driving about 100km (maybe a coincidence). The error was removed only after regenerating the injectors, checking the pump and replacing the guts of the fuel dragon. The cost is PLN 5,500 :(
    With a mileage of over 150,000, unfortunately such things happen in modern engines :(
