Mazda2 Diesel (1.5) - Difficulty Starting, Fuel Pump Pressure, Wipers Affecting Engine
6237 6
  • #1 16263555
  • #2 16264280
    dafit906
    Help: 91
    Rate: 515
    Behind the glove compartment on the passenger side, the fuse box, behind the fuse box, the fuel pump relay, a famous problem in the Mazda HDI. Restore the bundle to the original
  • Intermittent no-starts require manual fuel-system priming
    #3 16264484
  • #4 16264709
    dafit906
    Help: 91
    Rate: 515
    It is basically a relay that powers the fuel pressure regulator, fuel shut-off valve, EGR, flow meter, everything needed to start the engine. If there is a problem with it, or it is skipped or the power supply is "different", it may be as it is. Accurate diagnostics are advisable not only for reading errors.
    he only mentioned "" some "tile
    what does it mean?
  • #5 16264833
  • #6 16268010
  • #7 16305377
The discussion revolves around a recurring starting issue with a Mazda2 Diesel (1.5). The owner experienced difficulty starting the vehicle, which was diagnosed with low fuel pump pressure. Although the fuel pump was checked and deemed functional, the problem persisted after temporary repairs. The owner noted that the engine would stall when the front wipers were activated, suggesting an electrical issue. Responses from other users pointed to potential problems with the fuel pump relay and wiring connections. Recommendations included consulting an electromechanical specialist to inspect and possibly replace the wiring harness to ensure proper electrical contact and functionality.
