Mazda 2 (2003-2007) Diesel Engine Whistle at High Revs: Causes After Rollover & Flooding
Łukaszkalwar 5889 2
  • #1 16482401
    Łukaszkalwar
    Hello. I have a Mazde 2 2003-2007 with a diesel engine. In February my car skidded and rolled over. The engine was flooded. It has been cleaned, but while driving at higher revs, since I picked it up, you can hear a whistle coming from the engine. The car does not weaken when accelerating. What could be causing this?
  • #2 16482466
    andrzej20001
    Help: 1578
    Rate: 6669
    Only organoleptically you will find where the whistle is. Eat to a recommended specialist.
  • Listening test to locate whistle source
    #3 16483471
    Staszek49
    Help: 228
    Rate: 1140
    As suggested by the colleague above. Invite someone to help you to start the engine and increase the revs, while you (after opening the hood) have to listen to where the whistle is coming from. Depending on the place where the whistle comes from and the noise level, you can deduce what is wrong with the engine. This can be, for example, a leaky interkulator hose, a worn turbine, an accessory belt, seized timing rollers or alternator bearings.
