Renault Clio II ph 2 (2001) - Fuel Filter Location for 1.2 75 KM / 55 kW 16v Petrol Engine
zbyszek100 35190 11
Where is the fuel filter located on a 2001 Renault Clio II 1.2 16v petrol, and how is it accessed?
The fuel filter is by the fuel tank, underneath the car, so you normally need access from a lift or pit to get to it [#16263938][#16263964] It is not meant to be replaced every year; one reply says the manufacturer interval is 60,000 km or 48 months [#16263943] One post also notes that some Clio models do not have a separate external filter in front of the tank and that it may be inside the tank and not serviceable in the usual way [#16264654] If the car is losing power or going into limp mode, the thread advises reading the stored fault codes and checking fuel pressure instead of assuming the filter is the cause [#16264607][#16264699]
  • #1 16263922
    zbyszek100
    Rate: 207
    Hello, like a funny question, but always every year when changing oil and filters, one is omitted, specifically the fuel filter. Where he is and what the mechanic overlooks. The car is Clio II 1.2 75 KM / 55 kW 16v 2001 petrol
  • #2 16263938
    kkknc
    Help: 1914
    Rate: 6689
    He was not always there. As it is right next to the fuel tank.
  • #3 16263943
    mario 77
    Help: 66
    Rate: 335
    zbyszek100 wrote:
    and what the mechanic omits
    Skip, because according to the manufacturer's instructions there is no need to replace it every year. 60k. km / 48 months.
  • #4 16263954
    zbyszek100
    Rate: 207
    Well, from the information I have, I have not exchanged more than 100k km / 60 msec. And recently I have problems with electrics and maybe the filter came in with water, shit. I would like to name it, only where it is located.
  • #5 16263964
    mario 77
    Help: 66
    Rate: 335
    zbyszek100 wrote:
    only where he is specifically.
    Your colleague wrote to you (from below the fuel tank). The mechanic will know where to look and if you want to replace it yourself you must have access to the lift or channel.
  • #6 16264006
    kkknc
    Help: 1914
    Rate: 6689
    Yeah ... These two things have so much in common ...
  • #7 16264367
    zbyszek100
    Rate: 207
    If it's ironic to read on the forum that there were cases, after replacing the fuel filter, the spiral control has stopped. Either case or something.
  • #8 16264512
    kkknc
    Help: 1914
    Rate: 6689
    A spiral is a registered error. For example, low fuel pressure with a clogged filter. But how is this related to electrical problems?
  • #9 16264573
    zbyszek100
    Rate: 207
    My problem is that during the drive I am suddenly cut off by the engine's power, the speed drops to a minimum (here the spiral ignites - emergency mode?). After the car is blown, the turnover is back to normal. Maybe the filter is so clogged that I do not get enough fuel and hence this fault?
  • #10 16264607
    kkknc
    Help: 1914
    Rate: 6689
    Your problem is that you are just begging instead of starting from the simplest of activities like reading the recorded errors.
    And proceed further along the diagnostic path to solve the problem.
  • #11 16264654
    zbyszek100
    Rate: 207
    kkknc wrote:
    reading of registered errors.
    The problem is determined by the weather factor, frost, humidity, so I do not know if there's anything I can do here. According to the diagnostics, it has already been done; replacement of the gas pedal, soldering of cables without ankle, replacement of candles, coils. The errors that appeared then were: Przeprzepnica / pedal position sensor / switch A - fault, Switch operation - normal / performance - fault. They are the same now. That's why I thought about the fuel filter. What is your assessment of this?
    Added after 17 [minutes]:
    I buried a bit and from what I read the Clio 8V model has no filter on the bottom in front of the fuel tank. He is in the tank, but he works on the principle of "anti-statics" or something, and he does not exchange or clean it. It does not look like a filter. I remember that when we had a car on a hoist, we could not locate it in front of the tank. Is it possible that the 16V model is the same?
  • #12 16264699
    kkknc
    Help: 1914
    Rate: 6689
    No matter for the fuel filter. Time for diagnostics. And fix the problem. The pressure of the fuel is not dependent on the weather. Either he is either gone and you measure it with an ordinary pressure gauge.
✨ The discussion centers on the location and maintenance of the fuel filter in a 2001 Renault Clio II with a 1.2 75 KM / 55 kW 16v petrol engine. Users note that the fuel filter is typically located near the fuel tank, and it is not always necessary to replace it annually, as per manufacturer guidelines suggesting replacement every 60,000 km or 48 months. Concerns arise regarding potential electrical issues linked to a clogged fuel filter, with one user experiencing power loss during driving. The conversation highlights the importance of proper diagnostics and suggests that the fuel filter in some Clio models may not be easily accessible or replaceable, as it could be integrated within the fuel tank.
