Clio 3 1.2 16V Fuel Filter Location: Need Help Identifying the Filter Position
Kazikj11 42336 9
  • #1 17293862
    Kazikj11
    Rate: 13
    Hello, I have a problem where there is a fuel filter in this Clio model.
  • #2 17293884
    pszczyna
    Help: 211
    Rate: 395
    the filter is near the tank, replacement very trivial but you need a channel or a car tilt
  • #3 17293887
    piotrekwoj1
    Help: 934
    Rate: 3379
    The Renault Clio 3 fuel filter is located at the fuel pump in the fuel tank. Access after raising the rear seat.
  • #4 17293916
    Kazikj11
    Rate: 13
    The fuel tank wheel is carbon from vapors. I can't see normal transit
  • #5 17294112
    pszczyna
    Help: 211
    Rate: 395
    You could give the year and designation because in my materials it still points to the line or fuel line
  • #6 17294209
    Kazikj11
    Rate: 13
    2008r 75koni.
  • #7 17294280
    milejow
    Help: 1558
    Rate: 5110
    Because it is not there, the filter is an integral part of the pump basket.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #8 17294542
    pszczyna
    Help: 211
    Rate: 395
    All my catalogs indicate flow, even Filtron indicates PP831 / 1 for all gasoline versions
    Mann-Filter. -No .: WK 6002
    Bosch Art.-No .: 0 450 902 161
    Blue Print Art.-No .: ADN12324
    Febi Bilstein Art.-No .: 32399
    Filtron Art.-No .: PP831 / 1
    Mahle Art.-No .: KL 416/1
    Purflux Kraftstofffilter Art.-No .: EP210
    Hengst Art.-No .: H107WK
  • #9 17294577
    milejow
    Help: 1558
    Rate: 5110
    pszczyna wrote:
    All my catalogs point to flow
    Mine too, which does not change the fact that he is not there :D
    I met several times that in the year after 2002 probably in Scenic II gasoline there was a standard filter next to the tank fastened with a fuel line from the pump but in Clio II ph2,3,4 or Clio3 I have never seen it.
    Działalność własna
  • #10 17294807
    pszczyna
    Help: 211
    Rate: 395
    On one of the French portals I found such a curiosity if the filter is in the pump then there is no need to replace it, I even browse intercars and even there are only external filters.
    You can see that here there will be circuses like Toyota even with a stupid rear window wiper, or VW golf 4 Siemieniecki Etka in versions 4 and 5 mentioned two types (two different sizes and materials differed only with the letters C and D) and Etka after the upgrade to version 6 with only one Silentblock silly ASO service
✨ The fuel filter for the Renault Clio 3 1.2 16V is located within the fuel pump assembly inside the fuel tank, making it an integral part of the pump basket. Accessing the filter requires raising the rear seat. Replacement is generally straightforward, but it may necessitate tilting the car for better access. Various sources indicate that there are no external filters for this model, and the filter does not need to be replaced unless the entire pump assembly is changed. Several part numbers for compatible filters from different manufacturers are provided, including Filtron, Mann-Filter, Bosch, and Mahle.
