Renault Clio II ph 2 2001 Gasoline 75 hp: Unusual Squeaking Noise While Driving at Low Speeds
zbyszek100 8535 5
  • #1 16578121
    zbyszek100
    Rate: 207
    Hello, in my Clio II ph 2 2001 gasoline 75 hp, 55 kW when driving straight ahead something squeaks, as if wiping from the front on the left. Such a rubber sound. You can also hear it when turning. However, at speeds over 30 km / h, the sound is lost. Until then, the sound frequency accelerates and stops at a higher speed. A sound like rubbing gum on my teeth. The question is, can the pads squeak without braking? During normal forward driving? In principle, when braking, the bigger or smaller sound does not change. I have new tires, changed to new ones before the season. I replaced pads and shields a month ago. Whether on the run or at ease is the same. Thanks in advance for your help.
  • #2 16578179
    helmud7543
    Help: 1216
    Rate: 1564
    I would check the bearing, possibly if something protrudes from the wheel arch - except that here, depending on which part of the wheel arch was rubbing, the sound should change significantly when turning.
    As for the brakes - check that the disc does not heat up too much. It would be more like some rubbish but it would quickly wipe it off.
  • #3 16584483
    zbyszek100
    Rate: 207
    Today I had more time, so I picked up the car and turned the wheel. In fact, on both sides it is like that, in the video right wheel, there is such a tickling:
    https://www.youtube.com/watch?v=DaAD4Lor-3U
    + on the left wheel it additionally brakes slightly like I'm spinning.
    Joint, placenta?
  • Need exact 745 mm right half-axle replacement
    #4 16598268
    zbyszek100
    Rate: 207
    We have a problem (with a workshop) in ordering bearings with a right half-axle (it turned out to be a common element), all of which have come to the workshop so far have turned out to be too short by a few cm. What the picture has a length of ~ 745 mm. I can't find anything about these lengths on the Allegro. Visually also as if they were different. I am asking for help, maybe someone has an idea where to look for it. The VIN also came too short. Clio II 2001 after lifetime gasoline 75 HP / 55kW
    Renault Clio II ph 2 2001 Gasoline 75 hp: Unusual Squeaking Noise While Driving at Low Speeds Renault Clio II ph 2 2001 Gasoline 75 hp: Unusual Squeaking Noise While Driving at Low Speeds Renault Clio II ph 2 2001 Gasoline 75 hp: Unusual Squeaking Noise While Driving at Low Speeds Renault Clio II ph 2 2001 Gasoline 75 hp: Unusual Squeaking Noise While Driving at Low Speeds Renault Clio II ph 2 2001 Gasoline 75 hp: Unusual Squeaking Noise While Driving at Low Speeds Renault Clio II ph 2 2001 Gasoline 75 hp: Unusual Squeaking Noise While Driving at Low Speeds Renault Clio II ph 2 2001 Gasoline 75 hp: Unusual Squeaking Noise While Driving at Low Speeds
  • #5 16599382
    gsm_virus
    Help: 240
    Rate: 191
    zbyszek100 wrote:
    We have a problem (with a workshop) in ordering bearings with a right half-axle (it turned out that they are a common element),
    Only for first replacement ;-)
    zbyszek100 wrote:
    all that have come to the workshop so far have turned out to be too short by a few cm
    my mechanist also cursed me a "klijówke" when replacing the drive shaft ... he mentioned that there was probably a transplant and they folded the drive shaft from Kangoo !!!
  • #6 16625675
    zbyszek100
    Rate: 207
    That's exactly how it is. It fits perfectly with Kangoo half-shafts. My mechanic spread his hands and I had to search on my own. And just from Kangoo it fits and is identical to the one that they took. Silence after exchange.
