Maximizing Supply Air Temperature Control in Semi-Automatic AC: Fabia 1 Engine Access & Solution
marcin_xyz 19896 2
  • #1 16264113
    marcin_xyz
    Rate: 28
    the case looks like I have semi-automatic air conditioning in the car. At the moment the most hot air blows, regardless of the position of the knob. Sometimes, after driving on the road, it switches to the same temperature as it is set, but it can be stated confidently that the regulation does not work.
    I found on the other forum all the instructions on how to get to this engine, but it is a lot of spinning and gouging. Is there any other way to get to the engine? Is this behind this plastic? (attachment)
    • Maximizing Supply Air Temperature Control in Semi-Automatic AC: Fabia 1 Engine Access & Solution DSCN0757.JPG (92.26 KB) You must be logged in to download this attachment.
  • #3 16308095
    marcin_xyz
    Rate: 28
    And if anyone knows if such a motor will be good: 6Q0820536B 132801357, I found on the Allegro to Polo, but after the photos it looks the same as the one to the skoda
