Audi Chorus Radio: Volume Control and Display Stack Malfunction - Possible Repair Options
motka92 15948 15
How can I fix an Audi Chorus radio that jumps to maximum volume when I turn the volume knob, and is a missing vertical display stack more likely a display fault or a connection problem?
For Audi Chorus/Concert 1 radios, the volume fault is usually a processor/digital potentiometer problem rather than a simple mechanical volume pot [#16271602][#16268459] On Symphony and newer units, the similar symptom is more often the pulser/encoder or its switch contacts, so the exact radio version matters [#16271602][#16301109] The display problem is more likely a connection issue than a bad display panel itself [#16268459] The practical first step is to check the connections and solder joints, especially around the display and control section [#16268423][#16268459]
  • #1 16267195
    motka92
    Gentlemen ...
    What do I need to buy to fix the volume control on my Audi Chorus radio ...
    Typical symptom ... when you try to turn down or volume up the volume, it goes to max.
    In addition, I have one vertical stack out of order ... is it the display's fault or some layout? possibly cold solder?
    Audi Chorus Radio: Volume Control and Display Stack Malfunction - Possible Repair Options Audi Chorus Radio: Volume Control and Display Stack Malfunction - Possible Repair Options
  • #2 16267321
    pawel16150
    Level 30  
    Help: 204
    Rate: 640
    the link to the auction went to priv
  • #3 16267416
    kris-644
    Help: 39
    Rate: 74
    To replace the processor or mounting the emulator that connects to the data bus ...
  • #4 16268409
    motka92
    Gentlemen and the display ??
  • #5 16268423
    pawel16150
    Level 30  
    Help: 204
    Rate: 640
    You need to check the connections.
  • #6 16268459
    wtełek1
    Help: 19
    Rate: 55
    The display is rather a connection problem and the potentiometer is a processor. Because it's a digital potentiometer :)
  • #7 16270248
    gsekulski
    Rate: 213
    I hook up on the subject. I have a similar problem with volume control on Symphony II radio. Ie turning the volume knob instead of turning the volume down or doing what I want.
  • #8 16271092
    tolo
    Help: 233
    Rate: 1177
    To start with, clean or replace the pulser in Symphony II.
  • #9 16271156
    damdam
    Help: 274
    Rate: 950
    check if the adjustments of other values (bass, treble, fader) also behave this way. if so, then the pulser.
    ACME Damian Michalski
    Boczna 3a, Żory, 44-240 | Tel.: +48XXXXXXXXX (Show)
  • #10 16271224
    gsekulski
    Rate: 213
    only the volume knob works like that.
  • #11 16271602
    kris-644
    Help: 39
    Rate: 74
    Audi concert 1 and chorus 1 - processor problem. Symphony and newer radios is a problem with the pulser or potentiometer :) That's all in the subject.
  • #12 16275334
    kamo502
    Help: 24
    Rate: 140
    This and I will get on the topic, by the way.
    Radio Concert I (cassette) of the A6 C5 starts automatically.
    After removing the key, the knob extended radio after some time can turn on and play itself.
    Knob inserted, problem not present (not noted)
    What could be the reason?
    The problem appeared alone. Nothing was altered, connected, removed (as far as the radio itself)
  • #13 16275580
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1709
    kamo502 wrote:
    Radio Concert I (cassette) with A6 C5
    What exactly are there three types?
  • #14 16277640
    kamo502
    Help: 24
    Rate: 140
    Will the photo itself help anything?
  • #15 16301109
    Sas_AS
    Rate: 70
    Well, nothing will change. If the radio does not turn on when the volume control knob is pressed and when it is turned on sometimes it turns on by itself, THIS may mean leakage or poor contact of the switch built into the pulse generator. There is a switch in the pulser which, after sliding the bar (knob), short-circuits the switching circuit and the radio plays. If you turn off the ignition, the radio will turn off with the car. If there is poor contact on the switch built into the pulse generator (wear, dirt, oil, moisture) the radio in the extended knob position will turn on automatically when the resistance rises above the switch-off threshold and falls back above the switch-on threshold. Often such radio damage occurs through amateur attempts to repair the volume control by mindless pouring with ip, oil, wd or other crap on the pulser (encoder, jog ... how call it so called). Such a radio turns on for 1 hour while the vehicle is closed, the ignition off or immobilized. It can (rarely, because rarely but sometimes) also turn off for a while during the road (these are extreme cases, when everything is already rickety, it can only be replaced).
  • #16 20031942
    Karok
    motka92 wrote:
    Gentlemen, and the display ??
    Were you able to repair your display?
The discussion revolves around issues with the Audi Chorus radio, specifically a malfunctioning volume control that causes the volume to max out when adjusted. Users suggest potential solutions, including checking connections and replacing the digital potentiometer or processor. There is also mention of a vertical display stack malfunction, with indications that it may be related to connection problems or cold solder joints. Other users share similar experiences with different Audi radio models, highlighting common issues with volume control mechanisms and suggesting cleaning or replacing components like the pulser or potentiometer.
