2N2222 Transistor Replacement: CTPN 2222 Compatibility Inquiry
MkkGxPompa 11160 13
Can I use a CTPN 2222 as a replacement for a 2N2222 transistor?
Yes, CTPN 2222 is practically the same as a 2N2222 and should work as a replacement [#16267631] The thread also notes that 2N2222 itself is generally available, so you may not need a substitute at all [#16267641] One reply lists BSXP65 as the exact equivalent, with BSXP59-61 and 2N2219 as other possible substitutes if a larger package is acceptable [#16267704]
  • #1 16267610
    MkkGxPompa
    Hello. Looking for a replacement for 2N2222 transistor, is CTPN 2222 a replacement?
    chisel
    Help: 102
    Rate: 171
    You can replace, practically the same. Although 2N2222 is generally available.
    psiata
    User under supervision
    Help: 38
    Rate: 40
    The 2N2222 transistor is generally available so it makes no sense to look for a replacement for it. even take the first link from the shore: https://sklep.avt.pl/tranzystor-2n2222.html. The TO-18 housing is also available: https://sklep.avt.pl/tranzystor-2n2222a-si-npn-40v-0-8a-0-5w-to18.html. And as for substitutes, once there were catalogs. If a colleague wants to, then I can look at the catalog for replacements for this transistor.
  • #4 16267659
    MkkGxPompa
    Thank you for the answers and best regards
  • #6 16269135
    psiata
    Help: 38
    Rate: 40
    Maybe it is already a monument, but as you can see it is still available. Here is an example catalog with replacements: http://elportal.pl/pdf/k01/33_06.pdf
  • #8 16269760
  • #9 16269940
    psiata
    Help: 38
    Rate: 40
    trymer01 wrote:
    Bieda z nędzą wrote:
    Plain BC338 replaces it perfectly.
    That is not true!
    In normal use - e.g. low frequency, control in the power supply or as a relay switch, etc. - yes, BC337 etc. will replace it. But 2N2222 is a switch transistor - fast and in this role no BC can replace it. And here the author gave no application, he asks for a full replacement.
    Humans, 2N2222 is a 60s transistor, most modern low current bjt has better parameters.
    In simple terms, it can be said that everything good at BJT was "invented" in the 1960s (and in the early 1970s) - including 2N2222, 2N2369, 2N3055, 2N2219, BC, BF, BU ... later only the epiplanary technology (processes) was changed and improved, in the 90s special high-current and high-VFEat high-current transistors such as 2SC5706, etc. were developed.
    And therefore
    because nothing better in this category has been produced.
    That is not true!
    I will agree on this with the trimmer col. 2N2222 is a typical fast overwhelming transistor and it cannot be replaced by ordinary transistors of the BC series. e.g. BC337.
    because nothing better in this category has been produced. [/ quote]
    Yes, nothing better has been invented so far, but as we all know technology is still moving ahead and after some time improved versions of this transistor will probably come out on the market
    As for the transistor catalogs themselves, I recommend reading:
    https://www.elektroda.pl/rtvforum/zamienniki.html
    https://www.elektroda.pl/rtvforum/topic639634.html#3308186
    So for quickly found in my catalog replacements for 2N2222: BSW61, 2N4014, BSS40, BSS41, BSW64, BSR13
    For the sake of accuracy, I will compare 2N2222 and BC337 here to make it clear:
    2N2222:
    Ucb: 50V
    Ic: 0.8A
    Ptot: 0.5W
    hfe:> 100
    ft:> 250 MHz
    BC337:
    Ubc: 60-75V
    Ic: 0.5A
    Ptot: 0.8W
    hfe: 100-630
    ft: 100 MHz
    As you can see it is not the same
  • #10 16270244
  • #11 16270488
    psiata
    Help: 38
    Rate: 40
    Maybe now I break the rules and expose myself to these moderators, but I do not agree with the colleague's statement trimmer01. Here are sample links to replacements (with a few exceptions) that I specified in my last post:
    http://allegro.pl/tranzystor-bsw61-bsx-61-1a-70v-npn-to39-i5771761698.html
    http://www.digikey.pl/products/en?keywords=2N4014-ND&cur=USD
    http://inter-chip.pl/bsr13-16831.html
    As for switching times:
    for 2N2222:
    td = 10ns
    tr = 25ns
    ts = 225ns
    tf = 60ns
  • #12 16270528
  • #13 16271186
  • #14 16271278
✨ The discussion centers around the compatibility of the CTPN 2222 as a replacement for the 2N2222 transistor. Responses indicate that while the CTPN 2222 can be used as a substitute, the 2N2222 is widely available and often preferred. Various alternatives are suggested, including the BC337, BSXP65, BSXP59-61, and 2N2219, with emphasis on the 2N2222's characteristics as a switching transistor. The conversation highlights the importance of switching times and application contexts, noting that while modern BJTs may have better parameters, the 2N2222 remains a classic choice for specific applications. Links to datasheets and catalogs for further reference are also provided.
