C33716 Transistor Identification—Is It the Same as BC337 or a Different Component?
516 12
What is a transistor marked C33716, and is it the same as a BC337-16 or a different part?
It is the same device family: the marking C33716 is shorthand for BC337-16, not a different transistor [#21682588][#21682593] The “-16” suffix is the hFE gain classification, with the BC337-16 in the 100–250 gain range [#21682588] Another reply notes BC337-16 is typically around hFE 160, while BC33725 and BC33740 are the higher-gain variants [#21682589] A plain BC337 can have a much wider gain range, so the suffix matters when matching the part to a datasheet [#21682589]
  • #1 21682583
    Graham Rounce
  • #3 21682585
    Graham Rounce
  • #4 21682586
    Elizabeth Simon
  • Suggesting Atlas DCA55 testing for transistor ID
    #5 21682587
    Chip Fryer
  • BC337 suffixes indicate hFE classification
    #6 21682588
    Jack Grubbs
  • BC337 gain variants and hFE ranges
    #7 21682589
    David Ashton
  • BC108 gain suffixes compared with BC337
    #8 21682590
    David Ashton
  • 2N2926 gain ranges identified by paint dots
    #9 21682591
    David Ashton
  • Asking whether C33716 should be BC337 prefix
    #10 21682592
    Graham Rounce
  • BC337-16 identified as a Pro-Electron transistor code
    #11 21682593
    David Ashton
  • #12 21682594
    Graham Rounce
  • Towers transistor selector recommended for device lookup
    #13 21682595
    David Ashton
The discussion clarifies that the transistor marked "C33716" is likely a BC337 variant, with the "B" prefix omitted or unclear in marking. The BC33716 is an NPN bipolar junction transistor (BJT) with a specific hFE (current gain) classification, typically in the 100-250 range. This suffix numbering (16, 25, 40) on BC337 transistors indicates different gain ranges, similar to older transistor series like BC108 which used letter suffixes (A, B, C) for gain classification. The BC337 series is a plastic TO-92 packaged transistor, commonly used as a low-power audio frequency transistor under the Pro-Electron numbering system, where "BC" denotes a silicon audio frequency low power transistor. Datasheets from manufacturers such as ON Semiconductor confirm these classifications. Users are advised to verify transistor characteristics using transistor testers like the Atlas DCA55. The discussion also touches on transistor numbering standards, comparing the European Pro-Electron system with the American JEDEC system, and references historical transistor selector resources for further identification.
TL;DR: “C33716” is a BC337‑16 NPN small‑signal transistor; the “‑16” denotes the 100–250 hFE gain bin across 3 classes. “The hFE for your BC33716 would be 100–250.” [Elektroda, Anonymous, post #21682588]
Why it matters: correct ID avoids biasing errors and ensures drop‑in substitutes work in audio and general‑purpose circuits.
Is C33716 the same as BC337‑16?
Yes. The marking often drops the leading “B,” so “C33716” means BC337‑16. Treat it as the BC337 transistor in the “‑16” gain class. This aligns with top‑mark conventions and the hFE binning described in the discussion. [Elektroda, Anonymous, post #21682588]
What does the “‑16/‑25/‑40” suffix actually mean?
It’s the manufacturer’s hFE (DC current gain) classification. “‑16” indicates an hFE range of 100–250, “‑25” is higher, and “‑40” is higher still. These classes let designers choose tighter gain targets when biasing small‑signal stages. [Elektroda, Anonymous, post #21682588]
How can I verify a C33716 without a datasheet?
Use a transistor tester such as the Atlas DCA55. Measure type (NPN), pinout, and hFE, then compare to the BC337‑16 range. If results match the 100–250 bin, label it BC337‑16 for inventory. “Do you have a transistor tester you can use?” [Elektroda, Anonymous, post #21682586]
What is hFE in simple terms?
hFE is a transistor’s DC current gain: collector current divided by base current. Binned parts (like BC337‑16) keep this value within a defined range for predictable biasing. Designers use it to set resistor values and ensure stage stability. [Elektroda, Anonymous, post #21682588]
Can I substitute a BC337‑25 or BC337‑40 for a BC337‑16?
Often yes, but recheck biasing. Higher‑gain bins draw less base current and can shift operating points. One post notes unbinned BC337 devices can range about 100–630 hFE, underscoring why bins matter for predictable results. [Elektroda, Anonymous, post #21682589]
Is BC337 a general‑purpose NPN I can buy today?
Yes. Contributors found distributor listings indicating current availability as a general‑purpose NPN. If your search returns BC337 when you type “C33716,” it’s matching the family correctly. [Elektroda, Anonymous, post #21682584]
Edge case: Why do search results show BC337 when I type C33716?
Top‑mark abbreviations drop the “B,” causing catalog searches to resolve to BC337. Confirm with a tester and relabel your stock. This avoids future confusion and mis‑biasing. [Elektroda, Anonymous, post #21682592]
Quick 3‑step: How do I identify and sort my C33716 parts?
  1. Test each device with an Atlas DCA55 to read type, pinout, and hFE.
  2. Tag parts 100–250 hFE as BC337‑16; higher bins as ‑25 or ‑40 if known.
  3. Note any missing prefix (“B”) on storage labels to prevent search errors. [Elektroda, Anonymous, post #21682587]
What does “BC” stand for in BC337?
Under the Pro‑Electron system, “BC” denotes a silicon low‑power audio‑frequency transistor family. The post explains common numbering schemes and why markings vary by maker. [Elektroda, Anonymous, post #21682593]
Will using an unbinned BC337 cause issues?
It can. Unbinned BC337 parts may span roughly 100–630 hFE, so bias points can drift from design values. For repeatable builds, prefer binned variants like BC337‑16, ‑25, or ‑40. [Elektroda, Anonymous, post #21682589]
Any historical context that helps me choose equivalents?
Earlier BC108 series used letter bins A/B/C for gain, similar to the numeric bins used by BC337. Knowing this helps map older designs to modern plastic‑package equivalents. [Elektroda, Anonymous, post #21682590]
Expert tip: why do markings sometimes look incomplete?
Manufacturers sometimes omit letters on small packages. One expert notes “manufacturers leaving letters and other things off,” so expect abbreviations like C33716. Always verify before soldering. [Elektroda, Anonymous, post #21682593]
Is there a quick rule to avoid mistakes when substituting?
Match the gain bin first, then confirm with a tester. If you must mix bins, rebias the stage. This prevents noise rise, clipping, or DC offset shifts. [Elektroda, Anonymous, post #21682588]
What tools or references help with large mixed transistor lots?
Use an Atlas DCA55 for fast sorting and keep a selector reference. One poster recommends classic selector guides for pinouts and cross‑refs when datasheets are missing. [Elektroda, Anonymous, post #21682595]
