Skoda Fabia 1.2 Engine Stalling at Low Revs: Possible Causes & Solutions (Fuel/Oil/Air Filters)
Nachon 21207 18
How can I diagnose and fix a Skoda Fabia 1.2 that stalls at low revs and idles out while driving?
Have the car scanned with a diagnostic interface and check the real cylinder compression with a proper pressure gauge; if the readings are really around 9.5 / 7.5 / 7.5 bar, the engine is already qualified for repair [#16268122][#16319524][#16319691][#16320076] If the problem is only at idle and the car still pulls normally at speed, a throttle/idle-air problem or air leak can be involved, but the forum repeatedly stresses that the missing sensor data and erased fault codes prevent a reliable answer [#16268178][#16319677][#16320076] One suggested mechanical check is valve tightness through the spark-plug hole, because burned/leaking valves can cause low compression and stalling [#16320045] The “oil test” mentioned in the thread means a compression test with oil added, not the engine oil level, and it is used to help confirm where the compression loss comes from [#16319524][#16319679] In short, the likely path is: read fault codes, measure compression properly, and if low compression is confirmed, plan an engine repair rather than replacing filters or the throttle blindly [#16268122][#16319677][#16320076]
  • #1 16268042
    Nachon
    Hello, as this is my first post please forbearance., Going to the stuff, I need someone who tells me something, or maybe he had a similar problem, because I will replace half the car and the nervous system. Well, I'm running out of engine at low revs (Fabia) and this while driving. Specifically, what I mentioned;
    -fuel filter
    -oil filter
    - air filters
    - a clutch specified
    - throttle valve
    -distribution
    - new candles
    -auto has 119 thousand driven, I am the first owner straight from the factory, the car is 11 years old, in total not ridden and such eggs.
    What do you propose? maybe one of the mechanics recommended to make some bushings in the engine :) it means de facto overhaul of the engine, advise something, because it is getting better. For two years I would like to hurt myself to 150,000 and I will give it back to my neighbors, how to sell it? Well, unless you can fix it.
    greetings.
  • #2 16268122
    Jarosx9
    Help: 265
    Rate: 401
    Interface diagnosis and error analysis. The engine will read as soon as a dozen / tens of zlotys.
  • #3 16268178
    marfur30
    Help: 138
    Rate: 386
    It looks like a throttle problem or a leaky leak, but just like a colleague Jarosx9 wrote the diagnosis will say something more.
  • #4 16268848
  • Low piston compression points to engine repair needed
    #5 16319223
    Nachon
    Hello, none of your advice unfortunately did not help, I was in 2 plants and gave up. In the ASO they found low pressure on the pistons, and the silinik to be repaired right away and on them :) I am asking if it will help the heads to cut off they do not give. The state for today is tai, that at free revolutions goes out and no one knows what the reason is. In total, it is an insoluble matter for Krakow as you can see.
  • #6 16319323
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    What is the pressure?
    Was a computer diagnosis made?
    What did she show?
  • #7 16319524
    jerry1960
    Level 37  
    Help: 285
    Rate: 1560
    If the ASO checked the compression pressure, how much was it. Again, measure the compression pressure with the oil test.
  • #8 16319598
    Nachon
    A computer diagnosis was made, it is a 3-cylinder engine, on one there is 9.5 on two 7.5 and 7.5. All mistakes erased.
  • Seek an independent mechanic after verifying low compression
    #9 16319677
  • #10 16319679
    Nachon
    Thanks for the tip, I can say that there is a clue, because I basically have the oil in a normal way but sometimes my control squeaks. Then I check and it's ok. I did not even think about it, it could have a relationship.
  • #11 16319691
  • Verify cylinder compression with a pressure gauge
    #12 16319726
    Nachon
    Unfortunately, just as my colleagues write and rightly so, there is no information on the engine operation parameters of all sensors and valves, no engine errors, although there should be an error in your case.
    I did not get anything like the pressure on the pistons. nobody said anything about errors on the engine. Maybe it's the same? By Laikiem I am at least in the engine I know quite well :)
    [/ quote] As you can see, however, it amuses you, what can and actually the renovation should be done, although I will not give a head, because with such a course it is difficult to find no preliminary data as above.
    Or rather a small question, and whether the ASO did not encourage the purchase of a new car by accident, because it would be easier for them to repair the car. :twisted: . [/ Quote]
    He is enjoying it, because I have two options either to go crazy or approach it with amusement. Things have been going on since November. As for the car, they did not offer a new one, but I do not think they would ever buy anything from the Volkswagen group. Simply, the hands are falling and it is not surprising that the population in their drive so for the Japanese or Koreans is rushing. And I will not say a bad word about ASO, because nice guys, but the effect is not there.
    [/ Quote]
    The only advice is you should look in your area for those who once worked in the ASO and set up your company, which will definitely help you. [/ Quote]
    That is how he combines in this direction.
    Added after 4 [minutes]:
    What did they measure and measure?
    If the measurements taken on the basis of the current consumption, they may differ from the reality, which is the best solution by checking the candle and using a pressure gauge check the pressure on the cylinders, because only the most accurately can be checked.
    I do not know what they measured, because I did not have access to it as it is in the ASO, but I did not know that it can be checked differently.
  • #13 16320045
    grala1
    Help: 1495
    Rate: 5052
    Let someone check the tightness of the valves by applying pressure through the hole on the candles.
    Maybe you have the valves on fire.
    Read what is an oil test because it has nothing to do with the oil in the engine.
  • #14 16320076
  • #15 16320143
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Fabia 3 cyl is known and 7.5 bar compression.
    I have a question about how much and what oil did you pour? Does he kick you and take oil?
  • #16 16320160
    Nachon
    Gentlemen, thanks for all the tips, I already know what to ask this time and what to ask for. The problem is that I do not know it completely because I would research some things myself and probably get to what it is. Well, but now I answer questions;
    1) there is no power drop at all, when I go it goes like a rope, it collects at once, it just jerks and goes off at idle.
    2) Do not smoke at all, everything is clean, the oil I added was statoil, there also always refueled, the engine dry oil did not take at all.
  • #17 16320164
    Help: 1405
    Rate: 6430
    And when you exchanged oil and what.
  • #18 16320183
    Nachon
    a month ago, a little over when they changed the timing, they exchanged at w 10 for Orlen
  • #19 16320614
    manta
    Help: 463
    Rate: 1533
    I'm closing, for lack of meaningful data verification. Even this department has its limits.
The discussion revolves around a Skoda Fabia 1.2 engine experiencing stalling at low revs. The owner, a first-time poster, describes the issue and lists potential components for replacement, including fuel, oil, and air filters, as well as the throttle valve and spark plugs. Various responses suggest conducting a thorough diagnosis, including checking compression pressure and the throttle system, which may be malfunctioning. The owner reports low compression readings on the cylinders and expresses frustration over the lack of solutions from mechanics. Suggestions include checking valve tightness and ensuring proper air intake. The owner confirms no power loss during driving but experiences stalling at idle. The conversation highlights the complexity of diagnosing engine issues without clear error codes and the importance of detailed mechanical checks.
