Peugeot 607 2.2 Hdi 133 km - engine failure anti-collision system failure
crazy_88 15717 11
What could cause the "engine anti-pollution system failure" message and U0121/U0122 communication errors on a 2004 Peugeot 607 2.2 HDi?
The fault was eventually traced to a clogged FAP/DPF: there was too much pressure difference on the filter pressure sensors, and the filter was to be removed [#16275672] The earlier U0121 and U0122 codes point to a communication problem involving the ABS/vehicle dynamics modules, not injectors [#16268428] The thread also notes that if the antipollution warning persists, the engine may be in a protection strategy and it is worth checking for intake air leaks, a cracked/intercooler pipe, a clogged air filter, EGR faults, and sensor readings with PSA-specific diagnostic equipment [#16269362] [#16270062]
  • #1 16268363
    crazy_88
    Help: 1008
    Rate: 166
    Hello, I have a problem with the peugeot 607 2.2 hdi 133 km from 2004. Namely, I got the message engine anti-collectors sysem failure and the chec engine light is burning. The car does not enter the service mode, it normally speeds up, does not melt and does not go out and starts perfectly. After connecting to the computer, two errors jumped out
    U0121 communication error with the abs module
    U0122 loss of communication with the vehicle dynamics module.
    What could be the cause of a fap filter or injections?
    szymitsu21
    Help: 343
    Rate: 1300
    Neither DPF nor INJECTORS.
    There is a problem with communication between the ECU and ABS modules
  • #3 16268466
    crazy_88
    Help: 1008
    Rate: 166
    thanks for the answer, but why is the anti-collector system defective on the display burning and there is no error from it in the computer?
    what causes this message besides fap, injections etc? and it's strange that the car did not enter service mode
    robokop
    Help: 1763
    Rate: 6372
    Read these errors with dedicated equipment, because we have nothing to talk about right now.
  • #6 16269712
    crazy_88
    Help: 1008
    Rate: 166
    Hello, I was at the diagnostics today in a workshop from the French and the guest checked the errors with the appropriate equipment for the peugeot and repeated the action no errors related to the check engine only the abs module. I noticed again that the check engine and antipollution lights up on the cold engine after erasing the error and burns all the time only goes out after erasing the error with the interface.
    So what steps to take? the symptom is missing, the car has been dragged along the beltway and nothing has been done
  • #7 16269741
    szymitsu21
    Help: 343
    Rate: 1300
    as I said before. Exclude it first.
  • #8 16270005
    crazy_88
    Help: 1008
    Rate: 166
    on Tuesday I am going to check the absu sensors and rings because there is also a problem with abs when braking at low speed because it turns on all the time and the control does not burn, I talked with the guy what deals with abs pumps and abs modules and said that it is not a fault pump or module but sensors.
  • #9 16270062
  • #10 16271960
    szymitsu21
    Help: 343
    Rate: 1300
    KotBury2 wrote:
    crazy_88 wrote:
    So what steps to take? the symptom is missing, the car has been dragged along the beltway and nothing has been done.
    Do the simplest things I told you about. There is probably a hole in the pipe, either intercooler corroded (especially in the lower part) and this is the cause of air leaks.
    Pzdr KotBury2
    do not you think that the emergency mode always saves an error in the ECU?
    you mislead it in my opinion.
    possibly removed DTC table and therefore no information about the fault.
  • #11 16272089
  • #12 16275672
    crazy_88
    Help: 1008
    Rate: 166
    hello problem found fap filter clogged too much difference on pressure sensors filter will be removed
The discussion revolves around a 2004 Peugeot 607 2.2 HDi experiencing engine failure and an anti-collision system failure, indicated by the check engine light and error messages related to communication issues with the ABS and vehicle dynamics modules. Initial diagnostics suggested that the problem was not with the DPF or injectors but rather a communication failure between the ECU and ABS modules. Further investigation revealed that the vehicle was in emergency mode due to persistent antipollution and check engine warnings, likely caused by a clogged FAP filter, which was confirmed after additional diagnostics. Recommendations included checking for air leaks in the intake system and ensuring the integrity of the EGR and exhaust systems.
