Peugeot 307 2.0 136km Gasoline: Anti-Pollution Fault and Catalytic Converter Error
Amino111 42084 9
Why is my Peugeot 307 2.0 gasoline shaking slightly at startup and showing anti-pollution fault and catalytic converter warnings, and what could the likely repair costs be?
Start with a computer diagnostic scan, because without it the fault is only guesswork [#14290721][#14291272] On a gasoline Peugeot, the warning points to the catalytic converter/engine management system, not a DPF [#14291225] One reported real cause was the intake air sensor in front of the manifold: it was loose because the plastic clips had broken, and after fixing that sensor the jerking, power loss, and catalyst fault disappeared [#19912842] Another suggested possible causes were damaged injection, the camshaft position sensor, or a loose connector on the wiring path [#14291272] So the safest way to prepare for costs is to read the fault codes first, then check the intake air sensor, ignition/injection, and related sensors before assuming the catalyst itself is bad [#14290721][#19912842]
  • #1 14290600
    Amino111
    Rate: 15
    Hi, I have a problem with the car peugeot 307 2.0 136km gasoline when it starts the engine starts it slightly shake and pops anti-pollution fault + catalytic converter on the computer the picture starts flashing once appears date with the hour and once the error alternately one and the other in advance thanks for help
  • #2 14290721
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    For starters, a computer diagnosis.
  • #3 14291106
    Amino111
    Rate: 15
    Any ideas what could it be? because he wants to be prepared for possible costs.
  • #5 14291189
    SzymonMeganeII
    Rate: 14
    It looks like you have a clogged DPF, if you drive a little on the road, the best solution is to cut DPF
  • #6 14291206
    Amino111
    Rate: 15
    Gasoline engine without gas 2.0
  • #7 14291225
    Stefanek09
    Help: 7
    Rate: 25
    I glued CI a few links higher you can read.
    PS. @SzymonMeganeII There is no DPF in the gasoline. As already this catalyst.
  • #8 14291270
    Amino111
    Rate: 15
    and whether driving with a clogged catalyst is safe because tomorrow I went to check it for a computer
  • #9 14291272
    SzymonMeganeII
    Rate: 14
    @ Stefanek09 I know, I thought it was the famous HDI
    As for the error, the best solution will be to connect to the computer and scan the motor electronics.
    Added after 7 [minutes]:
     more than the catalyst, I would bet the damaged injection may also be the sensor of the shaft position or also some ankle on the way, but without connecting to the computer, the diagnosis is like fortune telling.
  • Loose intake air sensor caused false catalytic fault
    #10 19912842
    emzetemi
    Gentlemen,
    I am writing to share my case with you because I suspect that a lot of people are still looking for a solution. I had the same problem. The anti pollution catalytic converter fault began to emerge. Replaced coil (ignition dropped) spark plugs, to no avail. The car drove after fixing the errors, sometimes a week, sometimes a month. I ignored one error that the computer detected (intake air sensor error), the foreman said that it would definitely not be a catalyst, a lambda probe. When I looked under the hood and located the sensor (it is right in front of the collector, visible to the naked eye, you don't even have to bend down), I was nervous on the one hand, and happy on the other. It turned out that the sensor did not stay well in place. He was loose if I don't say what. Apparently those plastic clips had broken off once and there was no holding. After repairing this sensor, as he took away with his hand. The car gained power, it does not jerk on a cold engine, it works on all cylinders (there is no catalytic fault). I have been driving for a long time, not sparing the car and there are no symptoms for the fault to return. I only have to replace the relay from the secondary air pump (car at low revs) but for this you need a car electrician (almost impossible to access the relay) the need to re-program it in the computer. Let me know if anyone else had such a case,
    Greetings!
The discussion revolves around a Peugeot 307 2.0 gasoline engine experiencing an "anti-pollution fault" and a catalytic converter error. The user reports engine shaking and error messages on the dashboard. Responses suggest starting with a computer diagnosis to identify the issue. Some participants mention the possibility of a clogged catalytic converter, while others clarify that gasoline engines do not have a DPF (Diesel Particulate Filter). A user shares their experience of resolving similar issues by fixing a loose intake air sensor, which significantly improved engine performance. Overall, the consensus emphasizes the importance of a thorough diagnostic check to pinpoint the exact cause of the errors.
