Peugeot 1.6 HDI FAP Anti-Pollution System Faulty: Error Meaning, Fuel Filter & Possible Solutions
kubuś1 58577 15
What does the Peugeot 'anti-pollution system faulty' warning mean, and what can cause it even after refuelling and changing the fuel filter?
The message is a generic 'exhaust gas treatment / anti-pollution system malfunction' warning, not the exact fault, so the real error code must be read with PP2000 or a proper diagnoscope [#10488142][#10490532] Likely causes mentioned in the thread are a clogged FAP/DPF, low additive fluid in a wet-FAP system, poor or winter-unstable fuel, a faulty differential pressure sensor, or fuel-pressure faults such as P0093/P0087 from a partially blocked fuel filter [#10488142][#10490532] In cold weather, users advised using good winter diesel, keeping the tank above about half full, and adding conditioner if needed, because paraffin/waxing fuel can trigger the fault [#10489622][#10490532] If the fuel filter is old or non-original, replace it; the additives and winter fuel need some driving time to flush through the system [#10490532] One report said the fault disappeared after fuel/booster changes, suggesting the issue can be fuel-related and temporary [#10497499]
  • #1 10488046
    kubuś1
    Help: 10
    Rate: 27
    as in the topic, the error was deleted on the website for 1 day.
    best fuel in town new fuel filter, where's the problem?
    what exactly does this error mean?
    thanks in advance
    I greet
    Moderated By Pawel wawa:
    3.1.13. (10.9, 15) It is forbidden to publish entries that violate the spelling rules of the Polish language, which are careless and incomprehensible.
    ZAZ-y
    Help: 16
    Rate: 61
    Ours is "Exhaust Gas Treatment Malfunction".
    Connect PP2000 and read errors.
    Reasons: clogged FAP filter (diesel particulate filter), lack of fluid in the FAP system tank (if there is "wet FAP"), poor quality fuel, a faulty differential pressure sensor may be.
    Read: http://www.peugeot-klub.pl/index.php?topic=39125.0
    http://www.peugeot-klub.pl/index.php?topic=39065.0
    http://www.peugeot-klub.pl/index.php?topic=39719.0
    It's best to drive to someone who has PP2000 and knows how to read errors.
    You provided too little data: model, year, fuel quality, method of use ...
  • #3 10488152
    autoas
    Help: 571
    Rate: 3924
    After all, "ZAZ-y" was on the website, what do you think was "read", and what else are we supposed to help?
  • #4 10488268
    ZAZ-y
    Help: 16
    Rate: 61
    I know "websites" that read with various inventions, delete, download $ ... then again the fault. Kubuś1 asked, I answered as best I could. However, he provided too little data to solve this equation, he did not even provide what the service read, what was the cause of the error, or the FAP burned out. With so little data, the Crystal Ball won't tell you anything. We can only support a colleague spiritually and direct them with appropriate questions.
    Regards
  • #5 10488496
    kubuś1
    Help: 10
    Rate: 27
    So I will give a few details
    307 2007 1.6 hdi 110 KM FAP, mileage 160 thousand. km shell vpower fuel from 10 thousand. km
    the fuel filter is 10,000 years old and it is not an original filter - I do not remember the name
    yesterday at a distance of 50 km it went out 20 times
    diagnostics - erasing errors, 100km fuel conditioner without any problems
    20 h parking garage overnight
    today 6 am temp. -23 * C 15 km without a problem, then the same, the same error
    next 50km - 20 failures, goes out, I pull the clamps, and about 2 km I go quietly, then the emergency mode, half of the power 1km and so non-stop, after an hour of driving, after which you reset there - full power, no problem except the flashing diode of the engine failure
    is it possible that the fuel heats up and no longer causes trouble?
    what about the 15km in the morning
    chaotic but I hope enough
    thanks in advance
  • #6 10488546
  • #7 10488613
    autoas
    Help: 571
    Rate: 3924
    How so what, probably the same "anti-pollution system faulty" all the time
  • #8 10488657
    kubuś1
    Help: 10
    Rate: 27
    yes, the "anti-pollution system faulty" error keeps coming back
  • #9 10488722
    autoas
    Help: 571
    Rate: 3924
    So let's go back to the starting point
    You know I will not be nervous .... I will translate this error for you = "have it repaired immediately"
    There was once a sketch like this:
    T: hey, where are you going?
    J: To the cinema
    T: for what?
    J: on "Quo vadis"
    T: what does that mean?
    J: where are you going?
    T: to the cinema
    J: for what?
    T: on "Quo vadis"
    J: what does that mean?
    T: where are you going?
    J: To the cinema
    T: for what?
    J: on "Quo vadis"
    T: to the cinema
    J: for what?
    T: on "Quo vadis"
    etc. etc.
  • #10 10488762
  • #11 10489074
    kubuś1
    Help: 10
    Rate: 27
    Now even the failure indicator has gone out by itself without any diagnostics or costs
    I will write tomorrow
    greet
  • #12 10489622
    zdziber
    Rate: 42
    I'm not sure if it is the same, but look for the reason in low temperatures and fuel. Top up with good fuel and try to have no less than about 1/2 tank. Possibly add the conditioner. I understand you park your car outside. I had similar symptoms - I started the engine, it took a long time to idle, as it pumped and warmed up the fuel and the problem disappeared.
  • #13 10490347
    kubuś1
    Help: 10
    Rate: 27
    I hope it's a fuel problem and it will pass. of this vpower from the shell I have 1/2 zboirnik I bought in a store with parts for the French, some concentrate. I went to statoil and I topped them up with gold, I will see tomorrow.
    ZAZ you are a guest, this is how I understand the electrode, I will not fix the fault myself if it is serious, but if I can eliminate, for example, fuel or something else, for which I have a mechanic who I have already visited. Wait three days on the site, I do not know which specialist is good, what equipment he has, etc. I can see there is a fault in the photocopier, please, here are some possible causes and let's look for them one by one and I understand your services in the same way. An error is displayed, then write 1. fuel 2 filter 3 injection etc. I do not have time for longer breaks at work, I pay clowns for better fuel and here it is probably linden, two years ago I froze in orlen
    now shell linden? I change the oil every 20K, with Total Quartz 5 or 0W 50 filters, expensive originals, I don't want linden.
    autoas - I will send you wishes "That everyone would be so helpful to you in every other area of life as you help others in your-amen"
    Greetings
  • #14 10490532
    kybernetes
    Help: 426
    Rate: 1488
    Kubuś1, do not stress and understand the impatience of colleagues who answer the same questions for the hundredth time in a row. The symptoms you describe indicate a problem with the fuel, it is a pity that you did not enter the fault codes - as a service technician, you should know how important it is to identify the fault! What is shown on the display is, as your colleagues wrote to you above - general information for a layman that there is a problem with the engine that may affect the purity of the exhaust gases and such information for the driver is required by the vehicle approval regulations. Read the real fault codes with the diagnoscope.
    In my eye, 95% of the codes are P0093 and P0087 - the problem with maintaining the fuel pressure on the injection rail due to partial blockage of the fuel filter. Reasons - incorrect fuel (paraffin) during frost, fuel filter wet, fuel filter not changed for a long time. If the mere replacement of fuel with winter fuel + or an additive of the conditioner does not bring the result, you can also change the fuel filter on your own. If and after that the problem persists - the service remains. A small note here - for all these additives and winter fuels to work, the filter must be thoroughly rinsed through them, so you have to drive a bit.
    Regards.
  • #15 10490838
    autoas
    Help: 571
    Rate: 3924
    Well, thank you, winnie, but I see that you slowly understand what kaman is about ... and you understood my allusion with the sketch
    No hints will give you anything, knocking you will not do diagnostics (although most associate diagnostics with reading error codes in a pseudo-service)
    Life will make you straight, although winter reveals a lot of ailments in cars ...
    You don't understand anything yet, but you will soon find out ..... you will learn as much as the client needs to know
  • #16 10497499
    kubuś1
    Help: 10
    Rate: 27
    All Saturday from the morning no problem (approx. 100 km). After the actions with boosters and fuel, it probably helped.
    The actual tests will take place on Monday.
    Why did no one write it before? It is 95% of cases in such frosts, it would save me nerves and time, probably also.
    Greetings
The discussion revolves around a recurring "Anti-Pollution System Faulty" error in a 2007 Peugeot 307 with a 1.6 HDI engine. Users suggest that the error may indicate issues such as a clogged diesel particulate filter (FAP), low fluid levels in the FAP system, or poor fuel quality. The importance of using high-quality fuel, particularly in cold temperatures, is emphasized, as well as the need for regular maintenance, including timely fuel filter replacement. Diagnostic tools like PP2000 are recommended for accurate error code reading. The author reports intermittent issues that seem to improve with better fuel and additives, indicating that fuel quality may be a significant factor in the problem.
