Charger HB-1206S-GS - Charging the battery "Lead-acid only & qu
Doktor-Granat 5733 3
  • #1 16268408
    Doktor-Granat
    Today I picked up a charger I bought a few days ago at the (new) Carcommerce HB-1206S-GS auction - I was worried by the description on the housing "Only intended for charging lead-acid batteries" (There was no mention of it on the offer page)
    I have a so-called battery maintenance-free by CENTRA CA530 Futura.
    I can't find anywhere information about what will happen, or what will be the consequences (sooner or later) in the use of both devices ??
    The battery is about 3 years old, but I would like it to serve a little longer, so I ask experts on the subject, because it is not my field :)
    Thank you in advance for your help. regards Krzysztof
    Piotr2608
    Help: 851
    Rate: 4487
    The CENTRA CA530 Futura is a lead acid battery mixed with calcium, so the charger is perfect.
    This charger should not be used to charge gel batteries.
    ZimTech Piotr Zimny
  • #4 16274898
    Doktor-Granat
    Thank you very much for the information. I consider the topic closed.
