MB W211 Reversing Camera Installation: Rear View Connection Guide & Steps
locospeed 12189 5
  • #1 16268656
    locospeed
    Rate: 15
    I have a question regarding the installation of the rear view camera. Namely, I have a very similar set, and if someone explained, where to connect in turn? I'm sending a bottle :)
    • MB W211 Reversing Camera Installation: Rear View Connection Guide & Steps podlaczenie-kamery-na-tyl-i-przod-samochodu.jpg (65.37 KB) You must be logged in to download this attachment.
  • #2 16268735
    sosarek
    Help: 9320
    Rate: 15533
    It may be similar, but it is not identical to yours.
    locospeed wrote:
    if someone explained where to connect in turn?
    The right cables are in the right places.
    Z
    Pka, Poznań, 60-850
  • #3 16268890
    locospeed
    Rate: 15
    Similarly, because the camera is different, the rest is the same .... and if I knew where to connect the control cable, I would not write a post
  • #4 16268898
    sosarek
    Help: 9320
    Rate: 15533
    locospeed wrote:
    If I knew where to connect the control cable, I would not write a post
    What does the instruction say about it? Not by chance under reversing light?
    What do you connect this camera to the air?
    Z
    Pka, Poznań, 60-850
  • #5 16268953
    locospeed
    Rate: 15
    [Quote = "sosarek"]
    What do you connect this camera to the air? [/ Quote
    I know that I connect the camera's power supply to the backside of the bulb only I do not know where to connect the red control cable that is next to the video cable ... from the camera and from the radio.
  • #6 16268959
    sosarek
    Help: 9320
    Rate: 15533
    The meter has a hand and check if it is connected to the video mass.
    You should connect the cable under Reverse Signal on the radio.
    Z
    Pka, Poznań, 60-850
