Wireless reversing camera - where and how to connect the receiver?
Marcian3 12363 8
  • #1 17534598
    Marcian3
    I have a problem where and how to connect the RECEIVER.
    I connect to the 2DIN radio
    When connected to a constant current from the 12v radio and in reverse gear, everything works. The camera image is there. However, when I throw back gear, it displays "no signal" on the radio screen, does not want to switch to the standard menu, but displays no signal from the camera all the time. The blue screen receiver raises the radio signal from the camera, even though it is no longer transmitting.
    From what I noticed, there are sets with an additional monitor or GPS
    I have the receiver below with an RCA cable and two cables (direct current and ground)
    The only places that come to my mind are the sensor in the gearbox in the manual or if someone has an automatic (unfortunately not me) is under the "R" lamp on the display next to the jack.
    Anyone have any other idea ??
    The receiver is located at the bottom of the photo.
  • #2 17534609
    kkknc
    Help: 1915
    Rate: 6709
    This is a problem of the radio, its settings or connection.
  • #3 17534622
    Marcian3
    It seems to me that the receiver is well connected.
  • #4 17534628
    kkknc
    Help: 1915
    Rate: 6709
    If you think it's ok then it's ok. Why are you writing then?
  • #5 17534994
    Marcian3
    Please read with understanding. He does not need Janusz's advice, but only a person who has encountered such a problem or has relevant knowledge.
    Moderated By CameR:
    Reg. 3.1.9. Do not be ironic and do not be mean with the other side of the discussion. Please respect dissenting opinion and other opinions in the forum.
  • #6 17535033
    kkknc
    Help: 1915
    Rate: 6709
    So stay Janusz alone with your problem.
    Because Janus has already connected you, it is good, but it is not because another, or rather the same, Janusz claims that it is not. And the smartest Janusz writes on the forum only the type of radio he does not know, he will not insert the connection diagram. Instructions for it too. He knows so well that he put a picture from the web interface for connecting the webcam because it is this fault, although it is not. And yet he knows it. But he doesn't even know what and how he connected it.
    So you got what you described. And probably another lamella of your kind will flash soon, they know how he did it on his radio.
    Think carefully.
    Moderated By CameR:
  • #7 17535034
    web69
    Help: 188
    Rate: 629
    And when you disconnect the receiver, the inscription no signal disappears? If so, the receiver's power supply must also be connected in the same way as the camera's power supply. And the whole wireless system is ... worth it.
  • #8 17536515
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    Marcian3 wrote:
    I do not want to switch to the standard menu, but all the time displays no signal from the camera.
    Where does your radio get the info to switch to the rear view camera input?
    Do you need a cable from the reversing lamp bulb connected or a CAN interpreter that recognizes reverse from the CAN bus?
    The mere delivery of the Composite Video - CVBS signal with an RCA connector is usually not enough to switch radio modes.
    It all depends on the type of radio - unfortunately it's a secret ...
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #9 17540334
    Marcian3
    Subject solved. The receiver was connected to the current from the reversing sensors button, which appears when the reverse gear is engaged.
    The connection diagram for this module looked like this - the red cable to the power and the black cable to the ground, nothing else.
    This system is suitable for the automatic transmission to be connected to the diode with "R" otherwise connect the current from the fuses or the gearbox sensor, which is in the lead anyway and all its wireless function goes to the head ;)
    Thanks for your interest and willingness to help
The discussion revolves around issues with connecting a wireless reversing camera receiver to a 2DIN radio. The user reports that while the camera image appears when the vehicle is in reverse, the radio displays "no signal" when attempting to switch to the camera view. Various responses suggest that the problem may lie in the radio's settings, the connection method, or the need for additional wiring to switch the radio input correctly. A solution was eventually found: the receiver was connected to the current from the reversing sensors button, which activates when reverse gear is engaged. Proper wiring was confirmed, with the red cable connected to power and the black cable to ground. For automatic transmissions, a diode connection to the "R" signal is recommended, while manual transmissions may require a connection to the gearbox sensor or fuses.
