Rear view camera - Rear view camera connected to the micro USB
golab24 12804 4
  • #1 16197142
    golab24
    I have the original reversing camera connected to the reverse gear bulb with 3 red, black and yellow wires.
    I want to connect it to the driving recorder, which output for the reversing camera has a micro usb connector, from which 5 wires run like from the cameras Red, Black and Yellow as well as Greens and White.
    How to connect it to make it work because connecting the same colors to the same does not work.
    • Rear view camera - Rear view camera connected to the micro USB images.jpg (29.17 KB) You must be logged in to download this attachment.
  • #2 16197256
    scotch
    Help: 78
    Rate: 148
    Maybe a friend will give you a webcam type, drawings like drawings so nice and colorful ... ;)
  • #3 16197324
    golab24
    The recorder is XBLITZ DUAL CORE
    link
    And the reversing camera something like this, it comes here that fits perfectly into the license plate light and is dedicated to my car model
    link
    Micro usb scheme:
    White D-
    Green D +
    Yellow and Black GND
    Red Vcc 5V
    Now I need Chinese RCA schematics and should it work when connected? (someone knows his diagram because I can't find it anywhere)
  • #4 16201448
    golab24
    So how is it possible to connect it or not?
  • #5 16201579
    scotch
    Help: 78
    Rate: 148
    XBLITZ DUAL CORE is a recorder with its own card on which the recording is saved. As for the second information on the page provided by a colleague is "very comprehensive", from the photo you can only conclude that the output cmposit video (yellow socket), audio (red socket), red wires (+ power supply), black (power minus)
