Chinese Flashlight Battery Voltage & Lenticular SMD Diode Usage
sasukepl 8631 4
  • #1 16269653
    sasukepl
    I wanted to repair the flashlight but I have a problem because the battery at the output shows the voltage in mV. so what voltage can it have. How much can one lenticular smd diode pull?
    • Chinese Flashlight Battery Voltage & Lenticular SMD Diode Usage 1486803335874645965688.jpg (556.79 KB) You must be logged in to download this attachment.
    • Chinese Flashlight Battery Voltage & Lenticular SMD Diode Usage 1486803313685-1627710955.jpg (678.54 KB) You must be logged in to download this attachment.
    • Chinese Flashlight Battery Voltage & Lenticular SMD Diode Usage 1486803282365486206543.jpg (807.82 KB) You must be logged in to download this attachment.
  • #2 16269698
    olekt2002
    Level 32  
    Help: 147
    Rate: 518
    sasukepl wrote:
    I have a problem because the output battery shows the voltage in mV
    So a corpse.
  • #3 16269787
    sasukepl
    the corpse wants to swap something. someone will travel
  • #4 16269829
    gimak
    Help: 615
    Rate: 1680
    Usually, such flashlights have three 1.5V cells, I replaced them with 1.2V batteries
  • #5 16270468
    komatssu
    Help: 98
    Rate: 166
    It looks like 2 gel (lead) cells connected in series, i.e. a voltage of 4V.
