Fiat Seicento 900 Starter Issues: New Battery, Fuses, Candles, Fuel Injection - Still Won't Start
mawerikzDG 11139 14
  • #1 16270637
    mawerikzDG
    Hello, I have a problem with my Seicento a month ago, he did not spin the starter, I pulled out, I checked the good one. I fired it a dozen times out of pride and it went, surprisingly, I found that the battery was dead, on the same day I went and bought a new one, I put it in and it went the first time. After driving 3km on a new battery, I left it for 3 hours at home and so far I do not want to start it, it's been about a week. The car spins, but won't start.
    I checked the fuses, replaced the candles, added fuel directly to the injection and nothing, although after refilling it started to spin more vigorously. I have no idea what to do next.
  • #2 16270724
    adrian.sobczak92
    Rate: 18
    Start by checking the spark.
  • #3 16270746
    carrot
    Moderator of Cars
    Help: 1307
    Rate: 3554
    The "key" code light goes out? After switching on the ignition, you hear the fuel pump for 3 seconds? the "carrot" injection light comes on?
  • #4 16270776
    jerry1960
    Level 37  
    Help: 283
    Rate: 1551
    Check what is missing spark or fuel. When the candles are dry, there is no fuel, when wet there is no spark.
  • #5 16274023
    mawerikzDG
    I did not check the sparks, because when I took off the hose and turned it (to get some fuel and thus check immediately if there is fuel injection), it spilled a bit, so I did not risk it. When I added 1/6 glass of fuel to the injection, when it was on the revs, it started to work better, after removing the candles 2 were wet, but that's probably because I added it.
    Oh, and as for the pump, when the car was still starting normally, the pump started (or pumped fuel) for hmm .. 2-3 sec, now it takes much longer 4-5 sec, overall it's a difference, but I don't think so sure it was the pump's fault when I added fuel directly to the throttle.
    Of course, I will check the spark as soon as this fuel evaporates :)
    The CODE is on all the time, but I don't pay attention to it, because with this code I've been driving for several weeks, if not months. Injection control lights up.
  • #6 16274615
    thomas48
    Help: 44
    Rate: 81
    It was raining and it was completely down.
    But you still have to check the spark and the fuel pressure.
  • #7 16274678
    mawerikzDG
    I'll check the spark today.
    As for the fuel pressure, can it be checked without a pressure gauge?
    I have one more question, should I see the fuel on the throttle when I turn the starter? (is fuel flowing in general)
    EDITED: Mute spark (checked on 2 sets of candles)
  • #8 16281184
    mawerikzDG
    So what ? For scrap .. :) ?
  • #9 16281381
    carrot
    Moderator of Cars
    Help: 1307
    Rate: 3554
    Why scrap it right away? You checked what you could, now you have to bring it to the workshop, let a specialist evaluate the repair
  • #10 16284490
    mawerikzDG
    Because the repair will consume 50% of the car's value. :)
  • #11 16284918
    carrot
    Moderator of Cars
    Help: 1307
    Rate: 3554
    Perhaps it is, perhaps not, but look at it from another angle: how much will you get in the scrap? from PLN 500. For something fit for driving you have to spend about 2k PLN, plus the costs of registration, insurance, etc. If this sc, apart from "giving up smoking", is technically efficient, the repair may be economically justified
  • #12 16284958
    ALIBABA I
    Help: 218
    Rate: 530
    Hello, mawerikzDG, in these Fiats, the shaft position sensor is almost a standard, and even when you are proud, you will be sure, replace this sensor.
  • #13 16285642
    mawerikzDG
    Yes, but the sensor was recently replaced, i.e. from a year ago, well, it does not smoke. When he first zpierniczył, he smoked pride, but could the shaft position sensor break down by firing on pride?
  • #14 16285744
    carrot
    Moderator of Cars
    Help: 1307
    Rate: 3554
    Could the shaft position sensor fail by firing on pride?
    No, he couldn't break this
    You can do such an attempt: under the rear seat on the right side of the car there is a lid, under which you will gain access to the fuel tank, dragon and pump. remove the plug and connect the bulb to the two thickest cables (black with purple and white, as far as I remember correctly), after turning on the ignition it should light up for 3 seconds and go out, if it lights up when turning the starter, it means that the controller "reads "engine revolutions and starts the pump, so it's not a shaft sensor
  • #15 16290269
    mawerikzDG
    The fuel is evidently pumping under a lot of pressure, when I remove the hose at the injection, so the pump works, but I have not seen fuel from the injection go out.
✨ The discussion revolves around a Fiat Seicento 900 that fails to start despite having a new battery, checked fuses, and replaced spark plugs. The owner reports that the car initially started after replacing the battery but subsequently failed to start after a short drive. Responses suggest checking for spark and fuel pressure, as well as the operation of the fuel pump. The owner noted that the fuel pump runs longer than before and that two spark plugs were wet, indicating potential fuel issues. Suggestions include checking the shaft position sensor and verifying fuel flow at the injection system. The owner expresses concern about the cost of repairs versus the car's value.
