Fiat Seicento - Power Loss, Choking, Jerking: Tried Candles, Cables, Stepper Motor & More
miki1203 7344 9
Why does my Fiat Seicento lose power, choke and jerk, and can I swap in a scrap ECU by removing the white immobilizer box?
Check for a vacuum/air leak first, especially all hoses and the hose to the MAP sensor, because a leak can cause jerking and uneven idle; one suggested test is to spray around the intake while the engine is running and see if the revs rise or fluctuate [#16858401][#16857153][#16858775] The MAP sensor hose runs from the throttle to the sensor screwed to the injection controller, so any crack or disconnection there can cause these symptoms [#16858775] If the problem started suddenly, also consider the shaft/crank position sensor and connect the car to a diagnostic computer with the correct 3-pin interface and separate +12 V supply [#16858675][#16858775] If you replace the ECU, it will only work directly if it is an unencoded unit; otherwise the ECU, immobilizer, key, and antenna loop must be a matched set [#16858662][#16856031]
  • #1 16855947
    miki1203
    Hello gentlemen, I count on your help
    My seicento loses his power and chokes and jerks :cry:
    I was connect under the computer could not connect to the driver
    I was looking for thinking, maybe this or maybe that
    Replaced
    Candles + cables
    Stepper motor
    Fuel filter
    I was cleaning the fuel pump
    Throttles cleaned the injection also
    Tomorrow I will see if the catalyst has fallen apart
    But I mean driver in general
    If I buy it on scrap metal, I can put it in and the car will go normally, I heard that it is enough to remove such a white cube from it, is it true someone can explain how to do it
    Thank you for every hint and I count on you
  • #2 16855962
    ForeverYoung09
    If you could, give some more parameters, what engine it is, which year, etc. :wink:
    And tell me how the engine is idling? Equally or not?
  • #3 16856031
    melas
    Help: 138
    Rate: 689
    If you manage to buy it without immo, you will start it. We are talking here of course about 900.
  • #4 16856561
    miki1203
    Seicento 1.1.1000 idle speed sometimes increases a little
  • #5 16857153
    ForeverYoung09
    How is it Did you check the catalyst? :wink:
    You can still look if it certainly doesn't take the left air somewhere, i.e. all the hoses etc. :wink:
  • #6 16857998
    miki1203
    The catalyst is in good condition, you have a good way to check the left air
  • #7 16858401
    recki-quadra
    Help: 16
    Rate: 59
    Piss on the snake with a walking engine. If the revolutions start to go crazy it means that the sucked suck is there and you have a hole there. You can use the starter - the same principle.
  • #8 16858662
    sandamiano
    Help: 161
    Rate: 354
    Before removing the screw, unscrew the fuse box (three 8mm wrench screws). If there is no immo fiat code behind it - it looks like this (the color may be black)
    https://i.ebayimg.com/images/g/snMAAOSwi0RX1piv/s-l300.jpg
    then the engine controller is coded, then you won't fire your engine unless you take this immobilizer, engine controller and ignition key because it's a set. Even if you do not have a Fiat code, you need an antenna - the loop from the ignition to the immobilizer - if you do not have in your car of course.
    The best option if the one you want to take with you is not a fiat code immobilizer - check also on the wire - the loop from the ignition switch if it is not there you can easily fire your on the one taken from another car. You can also search for punto 1.1 IAW6F.SB control box with the inscription FIAT 176 1.1 CM SPI ECOL. these ecole were factory mounted without a pair of immo so a greater chance of unencoded
  • #9 16858675
    Stermotorzysta
    Rate: 125
    It would be best to connect it to the computer anyway. I suspect that this is an SPI engine for which one of the electrode forum members wrote a very good diagnostic program.
    Did this choking etc start suddenly and does it occur in any particular conditions etc?
    Symptoms may also indicate the shaft position sensor ...
  • #10 16858775
    sandamiano
    Help: 161
    Rate: 354
    There is a 3-pin input and you need to specify + 12V separately on the interface otherwise it will not connect but you should know it. As for jerking - the MAP sensor is important in this respect - its vacuum hose from the throttle to the sensor which is screwed to the injection controller. The injection indicator lights up when this fault occurs when it rags and mussels?
The discussion revolves around a Fiat Seicento experiencing power loss, choking, and jerking issues. The owner has replaced several components including candles, cables, a stepper motor, and a fuel filter, and has cleaned the fuel pump and throttle injection. They are considering the condition of the catalyst and whether replacing the engine control unit (ECU) from a scrap vehicle would resolve the issue. Responses suggest checking the idle speed, inspecting for air leaks, and the importance of the immobilizer system in the ECU replacement process. Additionally, the MAP sensor and shaft position sensor are highlighted as potential causes of the symptoms.
