Selecting High-Quality SATA 3 Cable for SATAIII SSD: Comparing Speeds & Compatibility Issues
bogiebog 4533 4
  • Faulty SATA cable caused SSD detection and speed issues
    #1 16271261
    bogiebog
    Help: 2569
    Rate: 1530
    After 4 hours of fighting with the SataIII SSD, it turned out that the sata cable was to blame.
    I tested 3 different cables
    1st - sometimes the disk disappeared from the system or the speed testing programs (hdtune, crystal disk info, as ssd) did not detect the disk or delivered a crash, even MyComputer / manage / disks got stuck, as the system saw the disk, the speed was from 5 up to 70 MBs.
    2nd - speed 350 read, 250 write, but not all programmers saw the disk.
    3rd - read 500, write 480 (same as benchmarks on the network for this model)
    How to choose sata cables for sata iii disk?
  • #2 16271305
    310artur
    Help: 980
    Rate: 670
    The third one.
  • #3 16271398
    bogiebog
    Help: 2569
    Rate: 1530
    How to evaluate a cable when buying online or in a store to choose one that will have no problem with the Sata III standard.
    All 3 cables that I tested in the sata II port were OK.
    310artur
    Help: 980
    Rate: 670
    Don't buy online. Cables are not so expensive that you cannot buy them in a trusted store. SATA3 cables are just described. For SSD disks it is important that the cable is SATA3.
  • #5 16730675
    bogiebog
    Help: 2569
    Rate: 1530
    thanks people
