Determine SATA Version: Choosing Between SATA 2 or SATA 3 Hard Drive - Check Connector
38061 8
  • #1 16098802
  • #2 16098806
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8293
    Choose from SATA 3. Works with both the 2nd and 3rd generation interface without any problem.
  • #3 16098844
  • #4 16098973
    dt1
    Help: 7315
    Rate: 8293
    Check the specifications of your motherboard or laptop or check what chipset is on the motherboard, see the chipset documentation for information about SATA support.
  • #5 16099716
  • #6 16099920
    Dra98
    Help: 1321
    Rate: 1076
    aparatx wrote:
    I can't find information about SATA.
    Please enter the model of your motherboard or controller if it is connected separately.
  • #7 16100996
  • #8 16103699
    aarek68
    Help: 26
    Rate: 56
    aparatx wrote:
    The motherboard model is: JE50_HR
    If it is ACER ASPIRE SERIES 5560-7851 then it is Sata III.
  • #9 16104188
    witoj
    Level 30  
    Help: 110
    Rate: 138
    aparatx wrote:
    How can I check what sata connector I have on the computer?
    The easiest way is the CristalDiskInfo program and in the Transfer mode table you can check
The discussion revolves around the choice between SATA 2 and SATA 3 hard drives, with a focus on how to determine the SATA connector type on a computer. Users suggest opting for SATA 3 as it is compatible with both SATA 2 and SATA 3 interfaces. However, concerns are raised about the cost of SATA 3 drives and their performance limitations when used with SATA 2 connectors. To check the SATA connector type, users recommend reviewing the motherboard specifications or chipset documentation. One user identifies their chipset as Intel HM65 but struggles to find specific SATA information. Another user mentions that the Acer Aspire Series 5560-7851 supports SATA III. Additionally, the program CrystalDiskInfo is suggested as a tool to check the transfer mode of the SATA connection.
