Choosing the Best SSD Drive: Goodram CX300, Iridium Gen2, Adata SU800, or Transcend SSD370?
swistak1111 3342 13
Which SSD should I choose for an MSI H110M PRO-VD system: Goodram CX300, Goodram Iridium Gen2, Adata SU800, or Transcend SSD370?
The thread’s best-supported advice is to choose GoodRAM IRDM/IRDM Gen2 or, even better, move up to a larger 240–250GB SSD instead of focusing on the cheapest 120/128GB models [#17075700] [#17075704] [#17697798] dt1 says the Adata SU800 is only a “last resort” TLC drive, while drives with a good Marvell controller and MLC NAND are preferred [#17075700] A later post also notes that the GoodRAM IRDM GEN2 120GB is advertised at 550 MB/s read and 530 MB/s write, but no one in the thread gives a clear reliability verdict for CX300 or SSD370 [#17697713] If budget allows, users recommend stepping up to something like the Iridium Pro 240GB or Crucial MX500 250GB rather than buying a small 128GB SSD [#17075704] [#17697798]
  • #1 17075385
    swistak1111
    Hi!
    One year after buying the computer, I decided it was high time to buy an SSD drive. Here, however, I have a dilemma which disk to choose.
    I do not know if the components can interfere with the operation of the SSD drive if I have a SATAIII connector on the motherboard, but to be sure it will write it, maybe someone with, for example, such a board had a problem with the operation of one of the disks I mentioned.
    MB: MSI H110M PRO-VD
    RAM: 2x4GB 2133Mhz Patriot Viper DDR4
    GPU: GTX 1050Ti MSI Gaming X 4GB GDDR5
    CPU: i3 6100 3.7Ghz
    The drives I consider initially:
    ssd-goodram-cx300-120gb-sata3
    disk-ssd-goodram-iridium-gen2-120gb-sata3
    adata-su800-128gb-sata3
    ssd-transcend-ssd370-128gb-sata3
    Which one will be the best / most efficient disk and which has the lowest failure rate, I am green on this topic.
    I am also open to your suggestions.
  • #2 17075490
    Pedros050
    Help: 2471
    Rate: 3926
    Hello. I recommend one of these if you have a large budget? Samsung SSD 960 PRO 1 TB
    Samsung SSD 960 EVO 500 GB
    Plextor M8PeG 512 GB
    Patriot Hellfire 480 GB
    Samsung SSD 850 PRO 512 GB
    GOODRAM Iridium PRO 240 GB
    Samsung SSD 850 EVO 250 GB
    Crucial MX300 275 GB
    ADATA Ultimate SU800 128 GB
    ADATA Premier Pro SP920 128 GB
  • #3 17075647
    swistak1111
    Up to PLN 250, do you think that these 2 lasts in the 120GB versions will be better than, for example, GOODRAM IRDM?
  • #4 17075700
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    SP920 is OK, good Marvell controller and good MLC memory. The SU800 as a last resort, a TLC memory drive, is quite bearable. GoodRAM IRDM2, despite the seemingly uninteresting controller, is doing quite well (I did speed tests, but the 240GB model, in the second post, a colleague from Forum also threw the measurement of the 120, link below).
    When it comes to cheap drives, you can think of the Crucial BX300 (MLC), I will also provide a link to the test in a moment. If you want cheap and a lot, you can take a look at the Micron M1100 disk, it is a disk based on the same controller as the Crucial MX300 and equipped with 3D TLC memory. I will probably buy this disc next week and I will also check how it is doing, but I do not have any measurements yet.
    Benchmark Crucial BX300 / 120GB: https://www.elektroda.pl/rtvforum/topic3433803.html
    Benchmark GoodRAM IRDM 240GB: https://www.elektroda.pl/rtvforum/topic3416340.html
    The price of the Crucial M1100 is PLN 279: https://www.x-kom.pl/p/382690-dysk-ssd-micron-256gb-25-ssd-m1100-3d-nand-oem.html
    Test here: https://www.nikktech.com/main/articles/pc-har...on-1100-256gb-ssd-review?showall=&limitstart=
  • #5 17075704
    FxJ
    Help: 9
    I suggest you add up to 240GB Iridium Pro (1st gen - the better one) so that you can fit some FPS games
  • #6 17075973
    swistak1111
    I thought about it, but the funds do not allow for games and general data storage, WD EZEX 1TB will be used.
    Thanks for all the answers and suggestions!
  • Questioning Goodram CX300 and Crucial BX300 options
    #7 17697713
    kubaopp
    Rate: 31
    I am sticking to the topic and I am looking for such a disk up to 128GB
    from the posts above it appears that the best would be the DATA Premier Pro SP920 but the price kills.
    Ultimate SU800 is only 300MB / s on record, but it's a more attractive price.
    GoodRam IRDM GEN2 120GB a little over PLN 100 and interesting data:
    Read speed [MB / s]
    550
    Write speed [MB / s]
    530.
    Crucialu BX300 in X-kom PLN 109 attractive price, but some exotic name scares me away.
    Maybe someone will comment on the cx300 from goodram?
  • #8 17697798
    FxJ
    Help: 9
    Crucial MX500 250GB - PLN 200
    Seriously, buying a smaller one is not profitable.
  • #9 17697832
    kubaopp
    Rate: 31
    about PLN 100 for 128 GB and about PLN 200 for 250 GB what is so profitable here?
  • Recommend buying a larger system SSD than 128 GB
    #10 17697867
    FxJ
    Help: 9
    In half a year it will be worth 50% of its price, I have already invested the Samsung 860 EVO SSD in 500GB, I bought it for an external drive in the USB 3.0 pocket for PLN 40. I have a 500GB Plextor M8PeGN (M.2 NVMe) for the system. Also at the moment, HDDs and I have a lot of them are only connected when I need something from the "archive".
    I bought my first 128GB SSD drive in early 3013 for PLN 449 and so far I do not regret any zloty.
    If it is to be the main system disk, buy a larger one, because 128GB is almost nothing, think if you want to download a movie in 4K one day, you will need about 30-40 GB for one.
  • #11 17697959
    kubaopp
    Rate: 31
    128gb for the system is not enough?
  • #14 17698008
    Pedros050
    Help: 2471
    Rate: 3926
    I have been using one in a stationary per system and haven't noticed any problems with it yet.
The discussion revolves around selecting the best SSD drive among Goodram CX300, Iridium Gen2, Adata SU800, and Transcend SSD370 for a computer with an MSI H110M PRO-VD motherboard. Users express concerns about compatibility with SATAIII connectors and the performance of the drives. Recommendations include considering the Goodram IRDM, Crucial BX300, and Adata Ultimate SU800, with emphasis on the importance of MLC memory for better performance. Some participants suggest opting for larger capacities, such as 240GB, for better value and future-proofing. The consensus leans towards drives with good read/write speeds and reliability, while also considering budget constraints.
TL;DR: For SATA builds, 250GB SSDs run ~PLN 200, and “buying a smaller one is not profitable.” Choose 250GB over 120GB; pick proven models mentioned below. [Elektroda, FxJ, post #17697798]
Why it matters: This helps MSI H110M PRO-VD and similar SATA-PC owners pick a reliable, fast SSD within a tight budget.
What’s the best SSD under PLN 250 for this build?
Aim for a 250GB SATA drive near PLN 200, like the Crucial MX500. This capacity gives headroom for Windows, apps, and updates. As one expert put it, “buying a smaller one is not profitable.” Prioritise capacity first; then pick a reputable model. [Elektroda, FxJ, post #17697798]
Is 128GB enough for Windows and apps?
It can work, but space disappears quickly. “128GB is almost nothing.” Large files make it worse; a 4K movie can take 30–40GB. Go 250GB if you can swing it. That choice reduces juggling and keeps performance steadier under load. [Elektroda, FxJ, post #17697867]
SP920 vs SU800 vs GoodRAM IRDM — which should I pick?
Pick ADATA SP920 if available; “SP920 is OK, good Marvell controller and good MLC memory.” Choose SU800 only as a last resort; it uses TLC but remains bearable. GoodRAM IRDM2 performs well, with forum benchmarks for 120GB and 240GB confirming it. [Elektroda, dt1, post #17075700]
Is GoodRAM IRDM Gen2 120GB a safe choice versus older IRDM?
Yes. IRDM2 performs well despite its modest controller. The post includes speed tests for 240GB and references a 120GB result. If your budget is strict, the 120GB IRDM2 is a defensible pick for OS and a few apps. [Elektroda, dt1, post #17075700]
Is Crucial BX300 120GB a good buy despite the name?
Yes. The BX300 uses MLC NAND and appears in the thread as a solid budget option. A benchmark link for the 120GB capacity was shared. If you must stay at 120GB, it’s among the safer bets from the listed choices. [Elektroda, dt1, post #17075700]
Are NVMe models like Samsung 960 EVO or Plextor M8PeG worth it here?
Only if your budget is high. They appeared in a “large budget” recommendation list, alongside other premium options. With a PLN 250 cap, stick to SATA models suggested in the thread. You’ll still get a huge boost over HDD. [Elektroda, Pedros050, post #17075490]
What speeds should I expect from GoodRAM IRDM Gen2 120GB?
The quoted figures are 550 MB/s read and 530 MB/s write. Those numbers reflect the typical spec for this model and capacity. Real-world results depend on workload and remaining free space. Keep 10–20% free for best consistency. [Elektroda, kubaopp, post #17697713]
Is ADATA SU800’s ~300 MB/s write a dealbreaker?
Not if the price is attractive to you. The user highlighted write around 300 MB/s for SU800. For basic system use and general apps, it remains viable. Prioritise capacity if you multitask or handle large files. [Elektroda, kubaopp, post #17697713]
Should I pair an SSD with a 1TB HDD for games and data?
Yes. The OP planned exactly this: SSD for the system and WD EZEX 1TB for storage and games. This hybrid approach balances speed with capacity. It keeps your budget in check without sacrificing responsiveness. [Elektroda, swistak1111, post #17075973]
Why choose GoodRAM Iridium Pro 240GB, and which generation is better?
Pick it if you want room for a few games. “1st gen — the better one,” so check the generation when buying. That nuance helps you avoid a less capable revision. It’s a smart stretch if funds allow. [Elektroda, FxJ, post #17075704]
Is Silicon Power A55 256GB okay as a system drive?
A forum member runs it as a desktop system disk and reports no issues. For budget builds, that user feedback is reassuring. It delivers the everyday speed jump you expect over HDDs. [Elektroda, Pedros050, post #17698008]
Is Micron M1100 256GB worth considering at around PLN 279?
Yes, if you want capacity on the cheap. The post lists PLN 279 for 256GB and notes it shares a controller lineage with Crucial MX300 and uses 3D TLC. A review link was also shared for deeper checks. [Elektroda, dt1, post #17075700]
Quick 3‑step: How do I pick the right SSD for this setup?
  1. Target 250GB capacity for the best value.
  2. Budget about PLN 200 for that tier.
  3. Choose a known model (e.g., Crucial MX500 250GB) and avoid 120GB if possible. [Elektroda, FxJ, post #17697798]
