Ford Mondeo MK3 2.0 TDDi 116KM - Goes out while driving or when not in use
Margol007 9555 12
Why does a Ford Mondeo MK3 2.0 TDDi randomly stall while driving or idling, show a flashing glow plug light, and then restart immediately after switching the ignition off and on again?
The fault is most likely an electrical or fuel-control issue, so the first step is to read the diagnostics because the flashing glow plug light indicates a stored fault [#16820093] A reported cause was the pump relay, which one user replaced with the rear window heater relay because it is the same type, and another said this relay sits under the battery [#16820048][#16820168] Another user reported that replacing the instrument cluster/clocks fixed the same stalling problem completely [#17083843]
  • #1 16819996
    Margol007
    Hello all.
    For some time while driving (but at a standstill too) the engine in the car goes out of my way. The counters display a flashing glow plug indicator and the tachometer remains in the last position. The problem appears without any rule, i.e. sometimes I can ride a month and nothing and sometimes one day will go off a few times. To start it, just turn the ignition off and start the engine immediately, which does not cause any problems for the car.
    Does anyone have any suggestions or have someone ever solved such a problem at Mondeo?
  • #2 16820048
    rosak
    Car dashboards specialist
    Help: 142
    Rate: 559
    I once had a similar problem, although it may be different for you. The pump relay was to blame. I replaced it with the rear window heater relay because it's the same.
  • #3 16820093
    Cobrat
    Help: 35
    Rate: 501
    If you get a flashing light of glow plugs, the driver catches the fault ... Diagnostics, not divination of tea leaves. And it can be said that injections, because at the friend's fella he also extinguished while driving, but you will have something else ...
  • #4 16820096
    Margol007
    Is it a fuel pump or injector relay?
  • #5 16820103
    rosak
    Help: 142
    Rate: 559
    I do not remember, but I've already given you a clue. One of them is the same as the rear window heater relay. By the way, it does not seem to me that the injectors themselves have relays, but maybe I do not know.
    The other thing is that Cobrat rightly suggests. I also wrote that this was a fault with me, you can be completely different.
  • #6 16820106
    Cobrat
    Help: 35
    Rate: 501
    Colleague is above all about the pump relay, there is no such thing as an injector relay.
  • #7 16820121
    Margol007
    But there is something like the injector pump relay.
    The Mondeo is marked as R8 and is responsible for an additional heater, glow plugs, an injector pump and a fuel combustion heater.
  • #8 16820165
    Cobrat
    Help: 35
    Rate: 501
    Read carefully again in what you wrote ...
  • #9 16820168
    Ciurejka
    Rate: 28
    As for this relay it is screwed under the battery, but from the diagnosis to start as colleagues have already written.
  • #10 17060803
    Hunter3012
    Rate: 10
    Have you already solved the problem of your fading Mondeo?
  • #11 17083843
    Hunter3012
    Rate: 10
    Hello!
    My friend still fights with the fading mondeo?
    The exchange of clocks helped me. As he took the hand away, the problem disappeared.
  • #12 17550486
    robertl2
    Rate: 9
    Hello!
    What clocks? I have the same problem.
  • #13 17560674
    Hunter3012
    Rate: 10
    A panel of clocks behind the wheel, the one you have all tachometers, counters, etc. here. It helped me, how he took it away.
The discussion revolves around a recurring issue with a Ford Mondeo MK3 2.0 TDDi where the engine unexpectedly shuts off while driving or at a standstill. The user reports a flashing glow plug indicator and a tachometer that freezes at its last position. Various suggestions are provided, including checking the pump relay, which can be replaced with the rear window heater relay. Some participants emphasize the importance of diagnostics to identify the fault accurately, while others mention that the problem could also be related to the instrument cluster, with one user noting that replacing the cluster resolved a similar issue. The conversation highlights the complexity of diagnosing intermittent engine shutdowns and the potential for multiple underlying causes.
TL;DR: Ford Mondeo MK3 2.0 TDDi stalling is commonly tied to the pump relay or instrument cluster; one poster had a 100% fix after an "exchange of clocks" (instrument cluster). "Start with diagnostics." [Elektroda, Hunter3012, post #17083843]
Why it matters: This FAQ helps Mondeo MK3 owners quickly triage random engine cut‑outs with dash light faults and frozen tachometers.
Why does my Mondeo MK3 2.0 TDDi randomly stall with a flashing glow‑plug light?
The ECU logs a fault and cuts power, which presents as a flashing glow‑plug lamp and a frozen tachometer. Owners report two recurrent causes: a failing fuel pump relay circuit and a faulty instrument cluster. The car usually restarts immediately after cycling the key. "Start with diagnostics" before swapping parts. [Elektroda, Cobrat, post #16820093]
Where is the fuel pump relay on the Mondeo MK3?
A contributor notes the relay assembly is mounted under the battery area. Access typically requires removing the battery and tray to expose the secured relay block. Expect corrosion or loose connections if water has pooled there. [Elektroda, Ciurejka, post #16820168]
Which relay powers the injector pump on this car?
Forum users refer to relay R8 as feeding the injector pump along with other heaters and glow plugs. If R8 fails intermittently, the engine can die while driving or idling, then restart normally. [Elektroda, Margol007, post #16820121]
Is there a separate injector relay on the Mondeo MK3?
No. An experienced poster clarifies there is no standalone injector relay; guidance typically concerns the pump relay circuit. Focus diagnosis on the pump relay and its supply. [Elektroda, Cobrat, post #16820106]
How can I quickly check whether the pump relay is the issue?
Perform a swap test. 1) Identify the pump relay. 2) Swap it with the rear window heater relay, which is the same type. 3) Road‑test for stalls. If stalls stop, replace the original relay. [Elektroda, rosak, post #16820048]
Can a bad instrument cluster make the engine cut out?
Yes. One owner eliminated stalling by replacing the instrument cluster (“clocks”); the problem disappeared after the swap. This aligns with frozen tachometer symptoms during cut‑out events. [Elektroda, Hunter3012, post #17083843]
Why does the car restart immediately after it stalls?
The stall is often an electrical power or signal loss, not a fuel starvation that needs priming. Cycling ignition restores power to the affected circuit, allowing instant restart without extended cranking. [Elektroda, Margol007, post #16819996]
How intermittent can this fault be?
Expect long quiet periods and sudden flare‑ups. One case ran fine for about a month, then stalled several times in one day. Such variability points to heat, vibration, or contact issues in relays or clusters. [Elektroda, Margol007, post #16819996]
What should I do first—scan codes or swap parts?
Scan first. A senior member advises, "Diagnostics, not divination of tea leaves." Read ECU codes when the glow‑plug lamp flashes. Then use targeted tests like relay swaps. [Elektroda, Cobrat, post #16820093]
Could the glow‑plug circuit itself be to blame?
The flashing glow‑plug lamp is a general fault indicator on these diesels, not proof of bad plugs. In thread cases, the root cause was power delivery or cluster faults. [Elektroda, Cobrat, post #16820093]
What’s an instrument cluster, and why can it stall the engine?
The instrument cluster is the gauge panel (“clocks”). Internal faults or poor connections can disrupt key signals or power, causing stalls and a stuck tach needle. Replacing the cluster solved one user’s issue. [Elektroda, Hunter3012, post #17083843]
Edge case: swapping relays didn’t help—what next?
If a relay swap changes nothing, inspect the cluster next. One owner’s stalling ceased only after changing the instrument cluster, despite relay checks. [Elektroda, Hunter3012, post #17083843]
Does the tachometer behavior tell me anything useful?
Yes. A tach needle that freezes at the last RPM while the engine dies points to electrical dropouts rather than fuel starvation. Owners reporting this symptom found relay or cluster faults. [Elektroda, Margol007, post #16819996]
What is a CAN bus, and is it related here?
CAN bus is the car’s data network linking modules like the ECU and cluster. Faulty clusters or power glitches can disturb signals, triggering stalls and warning lamps. Check power and cluster integrity first. [Elektroda, Hunter3012, post #17083843]
After replacing the cluster, do I need coding?
Cluster replacement may require pairing, but one user reported a simple swap resolved stalling. Verify immobilizer and warning functions after installation. [Elektroda, Hunter3012, post #17083843]
How do I explain the flashing glow‑plug icon to my mechanic?
Say the lamp flashes when the engine cuts, the tach freezes, and it restarts on key cycle. Ask for code scanning, relay R8 testing, and cluster evaluation. [Elektroda, Margol007, post #16819996]
