Electrolux ESL 66010 Dishwasher: i30 Error, Leakage & Pipe Seal Replacement Options
figurel 9891 5
  • #1 16272282
    figurel
    Help: 33
    Rate: 121
    The dishwasher after a few seconds after switching on indicates an i30 error and squeals. I turned on the water tray, the float apparently fulfilled its role and disconnected the circuit. After removing the water, the dishwasher started working but I noticed leakage from the place like in photos. Now the question is whether you can replace the same pipe-casing seal or seal is an integral part of the plastic pipe? Or maybe some assembly adhesive, silicon, sealant enough? If so, which one? Maybe car, high temperature np for oil pans (I have such at hand). Is this an exam?
  • #2 16272337
    Paw_el
    Home appliances specialist
    Help: 592
    Rate: 1551
    This is not a matter of sealing, just a damage to the thread on the water supply pipe to the upper propeller of the dishwasher.
    Naprawa Pralek Automatycznych Zmywarek
    Poznańska 46, Kalisz, 62-800 | Tel.: 62 XXXXXXX (Show)
  • #3 16272437
    figurel
    Help: 33
    Rate: 121
    Fact, I looked more closely, it is one whole, the tube at the end is threaded. Can you buy a whole tube? Where? How professional is it?
  • #5 16272559
    figurel
    Help: 33
    Rate: 121
    Paw_el wrote:
    Search for element with n-do 1528059007
    I think it should be this tube:
    I will buy, exchange and show off the effects.
  • #6 16288182
    figurel
    Help: 33
    Rate: 121
    I replaced the cable, the dishwasher works.
    Thank you, I'm closing.
