SID803 Engine Controller Replacement for Volvo S40 / V50: Immobilizer and EPROM Details
franek51a 29712 16
How can I replace a damaged Siemens SID803 engine controller in a Volvo S40/V50 and keep the immobilizer/key working?
To replace the SID803, transfer or clone the 95320 EEPROM; the flash chip marked in the photo is not the one you need [#16273173] If the replacement ECU has the same part numbers and compatible software, and matches the car’s manual/automatic setup, soldering the original 95320 is enough [#16273173][#16279035] If possible, read and save the EEPROM contents first with a programmer before soldering, just in case something goes wrong [#16273593] If the donor ECU is not from the exact same car/configuration, synchronization problems such as C326/C336 communication errors may require ECM/CEM sync and reading/writing the 95320 plus Motorola data from the CEM [#16279035][#16279744] In the thread, the car finally started once the original 95320 was moved to the replacement ECU from the same car, with zero errors after key insertion [#16281147]
  • #1 16272312
    franek51a
    Rate: 18
    Hello all!
    I have a damaged siemens sid803 engine driver by bad bdm connection (the adapter unfortunately has pins on the reverse)
    What do I have to do to get the second engine controller I bought with the immobilizer of the key? I heard that it is enough to solder the EPROM memory cube.
    I am not quite sure which is the bone so I send the picture.
    I will be very grateful for all information regarding the siemens sid803 driver replacement procedure
    • SID803 Engine Controller Replacement for Volvo S40 / V50: Immobilizer and EPROM Details sketch-1486894555264.png (3.52 MB) You must be logged in to download this attachment.
  • #2 16272534
    lugi666
    Help: 17
    Rate: 158
    Driver knelt by reading?
    If you read the entire driver through BDM, it should be enough to clone the replacement.
  • #3 16273031
    franek51a
    Rate: 18
    Yes, the controller fell during reading. You can not connect with him at all. I measured the power consumption and is 0.33A.
  • #4 16273129
    szymitsu21
    Help: 343
    Rate: 1300
    Translate the eeprom and the car goes on.
    As for more information, you would have to be too light :)
    Search and you will find, Flash is marked on the photo but he does not interest you.
    vollvek
    Help: 10
    Rate: 99
    If the driver is of the same numbers and has a soft compatible with what was either a manual or an automatic machine, all you need is an eeprom 95320
  • #6 16273216
    franek51a
    Rate: 18
    Thank you for answering this EEPROM 95320 is from the inside of the driver. On Tuesday, I will have the driver ordered. I will inform you how things look
    lugi666
    Help: 17
    Rate: 158
    If you have a programmer, first read the eprom content. As if something happened during soldering.
  • #8 16278937
    franek51a
    Rate: 18
    Hello all. ECU sid803 has been replaced. EEPROM 95320 too. There was only a problem with synchronizing ECU with ECM. the car reads the key but the engine can not be fired yet. Does anyone know how to synchronize the ECU with the ECM?
    szymitsu21
    Help: 343
    Rate: 1300
    I did not have to do synchronization as many times as I did.
    What does ECU say?
    vollvek
    Help: 10
    Rate: 99
    If the computer was from this car, synchronization should not be needed. Switch on the reading from the EEPROM. The driver was with the same Volvo numbers? I wonder if other software can be the cause.
  • #11 16279197
    franek51a
    Rate: 18
    Hello, ECU is reporting error c336 communication error with ECM. ECU the same 5ws40212g-t
    • s40 ecu.rar (408.77 KB) You must be logged in to download this attachment.
    • SID803 Engine Controller Replacement for Volvo S40 / V50: Immobilizer and EPROM Details 1487100205747-1136666744.jpg (2.8 MB) You must be logged in to download this attachment.
    • SID803 Engine Controller Replacement for Volvo S40 / V50: Immobilizer and EPROM Details 1487100179558-1286760678.jpg (2.68 MB) You must be logged in to download this attachment.
  • #12 16279427
    vollvek
    Help: 10
    Rate: 99
    Read EEPROM this 95320. This is for sure C336 and not C326?
  • #13 16279545
    franek51a
    Rate: 18
    So this is c326.
    I do not know how to read EPROM this 95320. I only have a Bdm100 adapter
  • #14 16279744
    vollvek
    Help: 10
    Rate: 99
    Well, you have a serious problem because it is necessary to read / write 95320 and motorola from CEM for synchronization.
  • #15 16279762
    franek51a
    Rate: 18
    Thank you for all the helpful information. I will call you tomorrow for service and I will ask you what is the cost of synchronization with them.
    Does anyone know where to find the CEM number?
  • #16 16280305
    adrian1201
    Help: 128
    Rate: 416
    Franek better go to the service on the carriage, or send it to someone with the necessary equipment because it looks worse, and do not touch it CEM.Pozatym there you still need to add something to synchro not only CEM and 95320.
  • #17 16281147
    franek51a
    Rate: 18
    Hello everyone!
    After a hard struggle the engine was started.
    I suspect the issue of software was the cause of yesterday's failure.
    Today came the second driver from my car which was of German origin as well as mine. After soldering my first eeprom 95320 and after inserting the key to the ignition, zero errors! The engine started.
    Thank you all for all the help and all information.
    Greetings!!!
    • SID803 Engine Controller Replacement for Volvo S40 / V50: Immobilizer and EPROM Details DSC_0039.JPG (2.79 MB) You must be logged in to download this attachment.
The discussion revolves around the replacement of a Siemens SID803 engine controller for a Volvo S40/V50, focusing on issues related to immobilizer synchronization and EPROM memory transfer. The original controller was damaged due to a bad BDM connection, prompting the user to seek guidance on transferring the EEPROM (specifically the 95320 chip) from the old controller to the new one. Participants advised that if the replacement controller has compatible software and numbers, cloning the EEPROM should suffice. However, synchronization with the Engine Control Module (ECM) was necessary after the replacement, as the user encountered a communication error (C336) initially. Ultimately, after addressing software compatibility and successfully transferring the EEPROM, the engine was started without errors.
