Volvo C30 2007 1.6D Burned CEM Module 31254317: Replacement Options & Programming Settings
slevy70 12192 11
  • #1 16298071
    slevy70
    Help: 42
    Rate: 206
    Burned CEM module 31254317. What can be replaced in place of the damaged one? Does it have to be with the same serial number, or is the replacement necessary? Will you need to program settings and adaptations?
  • #2 16298221
    adrian1201
    Help: 128
    Rate: 413
    In the sitting immo will not light, you need to program.
  • #3 16298368
    slevy70
    Help: 42
    Rate: 206
    Where is the information about immo in CEM? How to synchronize purchased CEM? And how is the case with these module numbers, can you replace e.g. 31254749?
    • Volvo C30 2007 1.6D Burned CEM Module 31254317: Replacement Options & Programming Settings P1010359.JPG (335.91 KB) You must be logged in to download this attachment.
  • #4 16298371
    adrian1201
    Help: 128
    Rate: 413
    The number must be bought, because it may vary in equipment.
  • #5 16298548
    Ringo24
    Help: 76
    Rate: 156
    Read the motorcycles and enter it into the new CEM.
  • #6 16299054
    vollvek
    Help: 10
    Rate: 99
    Another number may have different skeins and then you can not simply copy from the old one.
  • #7 16318276
    slevy70
    Help: 42
    Rate: 206
    New cem, right skein read and saved to the new skein, the car started, unfortunately the remote control does not work, the legs in the left skein are shortened 39 and 40 I can't read, is it possible to program the remote control again?
  • #8 16327523
    slevy70
    Help: 42
    Rate: 206
    So how is it possible to train original pilots for the new CEM after the service?
  • #9 16328373
    adrian1201
    Help: 128
    Rate: 413
    It is possible but you still need to read the motk.
  • #10 16328590
    slevy70
    Help: 42
    Rate: 206
    I wrote earlier that skeins cannot be read, power legs 39 and 40 are shorted
  • #11 16328974
    adrian1201
    Help: 128
    Rate: 413
    And how would I desolder? Or raise these legs?
  • #12 16329260
    slevy70
    Help: 42
    Rate: 206
    , I tried all the ways is fired.
✨ The discussion revolves around the replacement of a burned CEM module (part number 31254317) in a 2007 Volvo C30. It is emphasized that the replacement module should ideally match the original part number due to potential differences in equipment configurations. Programming is necessary for the new CEM, including reading and transferring settings from the old module. Users also inquire about synchronizing the remote control and the challenges faced when certain pins on the new module are shorted, which complicates the reading of necessary data. Solutions involve reading the motorcycle data and programming the remote control after service.
