Acer Aspire ES 15: No Bootable Device Error, BIOS Password & UEFI to Legacy Conversion Issue
nervasit 6060 10
How can I fix a bootable Acer Aspire ES1-533 when the BIOS is set to UEFI, the Legacy boot option is locked, and a USB installer still shows “No bootable device”?
This model may need to stay in UEFI mode, because after BIOS update 1.07 the Legacy option is no longer available [#17152604] Create a bootable GPT/UEFI USB stick with Rufus, because an MBR flash drive will not boot under UEFI [#17151610][#17152604] Once the USB is prepared correctly, you can install Windows 8 or 10, and Ubuntu should also work [#17152604] If Secure Boot is still enabled, it can keep the boot settings restrictive, but the thread’s main workaround is UEFI/GPT media rather than switching to Legacy [#17151637][#17152604]
  • #1 17150906
    nervasit
    Hello, today I got a laptop with the error "No bootable device" and a password for bios. The password from the bios has been removed, the bios can see the hard drive connected, but when you try to boot the system and install a new one, this error is still displayed with no device with the system. I read that you need to change Boot Mode from "uefi" to "legacy", but for me this option cannot be entered and it is set to "uefi".
  • #2 17150964
    barteksmrek
    Help: 89
    Rate: 224
    What laptop? Which year?
  • #3 17150979
    Matuzalem
    Help: 1653
    Rate: 1101
    What and what are you trying to boot from? Once that is settled, it will be easier later.
    As part of the supporting questions: Are you sure that there was an OS on the disk? - Its absence would explain the reaction to an attempt to boot from HDD (SSD).
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
  • #4 17150983
    nervasit
    As in the topic, Acer Aspire ES 15, unfortunately I do not know the year of production.
    Added after 16 [minutes]:
    Year of production 2016, the system is on a pendrive, it was formatted to fat32, then the system image was loaded with the Ultra ISO program. As for the disk system it is (checked on another laptop)
    Edit. Sorry, I was fooled by the name on the box. The model is ASPIRE ES1-533
  • #5 17151124
    tzok
    Help: 3175
    Rate: 6546
    If the password was removed without knowing it (deleted), then the disk most likely remained password protected. Laptops often put a password on both the BIOS and the disk. Removing the password from the BIOS with a generator renders the disk useless. Check on another computer that the disk is discoverable and that it is not locked with an ATA password.
  • #6 17151236
    nervasit
    Even before cracking the bios password, there was this "No bootable device" error. I cracked the password to enter the bios and change the boot order. Oddly enough, even when I set booting from a pendrive, there is also this error and the new installation of the system does not start
  • #7 17151610
    tzok
    Help: 3175
    Rate: 6546
    Check the disk in another computer. If you have UEFI (and Secure Boot is probably still enabled), you will not boot from an MBR flash drive.
  • #8 17151620
    nervasit
    It's under uefi how do i have to boot the pendrive? What program do you recommend?
    Anyone know why the "Boot Mode" option is locked and I can't change to Legacy?
  • #9 17151637
    tzok
    Help: 3175
    Rate: 6546
    Probably because you have Secure Boot enabled.
  • #10 17151641
    nervasit
    When I disable it, it will save the settings and reset the laptop, it is still locked
    They write everywhere on foreign forums that in order to get rid of "No bootable device" you have to change to Legacy
  • #11 17152604
    tzok
    Help: 3175
    Rate: 6546
    You're not the only one who has a problem with this laptop. From what I found out, it can only be used with UEFI, after updating the BIOS to 1.07 there is no Legacy option anymore. You can prepare a bootable GPT / UEFI flash drive using the RUFUS program. You can install Windows 8 or 10 without "magic", apparently you can also install Ubuntu.
    https://community.acer.com/en/discussion/4717...aspire-es-15-es1-533-c3uw-legacy-bios-missing
The discussion revolves around an Acer Aspire ES 15 (model ES1-533) experiencing a "No bootable device" error after a BIOS password was removed. The user confirmed that the hard drive is recognized in BIOS, but attempts to boot from a USB drive containing a system image also fail. The user seeks to switch the Boot Mode from UEFI to Legacy, but finds the option locked, likely due to Secure Boot being enabled. Other participants suggest checking the hard drive on another computer and using a bootable GPT/UEFI flash drive created with RUFUS. It is noted that after a BIOS update to version 1.07, the Legacy option may no longer be available, indicating that the laptop is designed to operate primarily in UEFI mode.
