beko cannot see the pots - the induction hob cannot see the pots on one side
thomashecc 41844 5
  • Possible wiring fault disabling the right induction zones
    #1 16276692
    thomashecc
    Rate: 33
    Hi. A friend connected my new induction hob today. It has four fields, however the ones on the right do not see the pots. The 2 fields on the left work OK. I'm wondering if maybe the wrong connection is to blame. Is it possible to connect the hob so that some fields heat and others do not? I am a total layman. I would be grateful for suggestions. Should I call an electrician or contact a service centre straight away?
  • #2 16276784
    Piotr2608
    Help: 851
    Rate: 4488
    Let's start with the album - the model.
    Secondly, incorrect connection of the disc may result in the fact that "half" of the disc may not work. The board is connected to one or two phases?
    ZimTech Piotr Zimny
  • #3 16276836
    thomashecc
    Rate: 33
    It is a Beko HII 64500 FHTW. Unfortunately I don't know exactly how the connection was made as I'm not familiar with it.
  • #4 16276874
    Piotr2608
    Help: 851
    Rate: 4488
    According to the instructions, is the appropriate heating zone turned on?
    ZimTech Piotr Zimny
  • #5 16276940
    thomashecc
    Rate: 33
    Yes, I'm doing everything right. The fields on the left detect the pot and heat up. On both fields on the right the icon flashes to indicate no pot. On the field on the left you can hear such a "snap" before the pot is detected. On the right, nothing happens, only the icon flashes.
  • #6 16442836
    thomashecc
    Rate: 33
    For posterity the solution:
    The service guy found a burnt-out power supply and replaced it without discussion. He found no misconnection. And the interesting thing is that after 2 months the power supply burned out again and they replaced it again. We will see for how long.
