Teka IR 641 Induction Hob: Left Side Working, F47 Error on Right Side - Potential Causes
agamik1 68653 25
What does the F47 error mean on a Teka IR 641 induction hob when only one side works?
F47 means a communication error between the induction module and the user interface, so when only one side works it usually points to that side’s module not getting power properly or not communicating, often because of a bad connection, a blown fuse, or a varistor fault [#7395077][#7627402][#20530180][#20530333] If just one side is affected, check the wiring/bridge and the connection diagram on the hob first [#7171346][#7394261] If the supply and wiring are correct and F47 still appears, the fault is likely in the module itself and service or module replacement is needed [#20530201][#7394736]
  • #1 7168567
    agamik1
    I bought the Teka IR 641 induction hob. After connecting, only the left side works, and the F47 error appears on the right side. What does it mean? Is the board badly connected or is it broken?
  • #2 7171085
    neptunka
    Rate: 21
    I have a similar problem - one disc does not work, it only turns on as the setting of the disc heating and level 6 ... in any other case, an error appears ... what is it? I have a samsung board, the connection is rather flawless in two phases
  • #3 7171346
    andrzej1959
    Home appliances specialist
    Help: 223
    Rate: 817
    agamik1 wrote:
    I bought the TEKA IR 641 induction hob. After connecting, only the left side works, and the F47 error appears on the right side. What does it mean? Is the board badly connected or is it broken?
    Who connected this board? It was probably badly connected, you have to look at the diagram on the board .
    I have had a few bad connection cases and only one side works then.
  • #4 7171706
    neptunka
    Rate: 21
    an electrician connected, I think it's good with the connection, because if something was wrong, it seems to me that this board (this field) would not work at all, and it only works on 6, and once it happened that it "clicked" on 3 .. .may this happen with wrong connection? is this not a disc defect? I see that there are a lot of titles on the forum, but I have not found a solution :( Today an electrician will come again and check, but I doubt it's a matter of wrong connection, we'll see ...
  • #5 7172259
    agamik1
    An electrician was connecting - only that the connection instructions do not specify how the plate should be connected, whether for 3 phases or 2 phases.
  • #6 7393750
    19tomi72
    Rate: 49
    I bought a Teka IR641 board, and when I plug in the board, the right side works. However, the error F47 is still blinking on the left. Does anyone know what this means and how to deal with it?
  • #7 7394261
    TomekCarlos
    Help: 89
    Rate: 585
    Damaged branch of one phase in the power supply - no power supply to one power module. Probably also badly connected.
  • #8 7394736
    eeban
    Help: 385
    Rate: 1497
    19tomi72 wrote:
    hello, I bought a folder, ir641, after connecting the board, the right side works on the left side, f47 is still blinking. does anyone know what it means and how to deal with it ??
    The board is on warranty so call the service
  • #9 7395077
    Karlheinz
    Help: 44
    Rate: 145
    With how badly connected, the service will delete the visit. Error F47 no communication with one side for 90% percent no reset bridge, and let the installer correct the connection ...
  • #10 7606609
    sir-zak
    Level 19  
    Help: 38
    Rate: 92
    I have had the disc connected since May and everything was fine until today. On the left side of the F47. The right side works. I did not have any voltage drop or jump.
    Rummage through connections?
  • #11 7606720
    eeban
    Help: 385
    Rate: 1497
    @sir-zak It should be under warranty and before calling the service check if the power supply to the board is ok ....
  • #12 7608180
    sir-zak
    Level 19  
    Help: 38
    Rate: 92
    Yes, everything is ok with the power supply, and do you know if the service comes to the place or you have to take the disc to them?
  • #13 7627402
    sir-zak
    Level 19  
    Help: 38
    Rate: 92
    I just had a service. Error f47 is a communication error, which TomekCarlos wrote about earlier. It occurs most often when connecting, because a fuse or a varistor is blown. In my case, it is efficient or fortunately, and the album went to the workshop. Probably a control board, but I will write about it in a few days (at least I hope so).
  • #14 9085947
    ahak1
    He also showed up for me error F47 I've only been using this CD for a year. If it's the result of a bad connection, why has it stopped working properly only now? I hope the warranty will cover it. Has anyone else had this problem and can an electrician fix it himself :?:
  • #15 10788642
    marciopez
    It surprised me this morning as well (the album has been working flawlessly for over a year). My husband turned off the electricity in the whole house for a while, after turning it on, everything was OK and there was no service.
  • #16 11686358
    rpostek
    For me, this error appeared only once, after three years of use. I disconnected the power from the board, plugged it in and everything works fine.
  • #17 19942739
    Tomasz M.
    Rate: 16
    I take a shovel and dig it out, because there is no point in setting up a new topic.
    The Teka IR 641.1 induction hob worked for several years OK, then the error code F47 appeared more and more often on the right side. And today, after the "reset" of the power supply, which often helped, this error appeared for a while on the left side as well.
    For now, the left side works fine and the right side works badly.
    To buy a new one, is there any sense in resuscitating it? Thanks for the hints.
  • Undersized 5x1.5 mm² factory cable suspected overheating
    #18 20076463
    Tomasz M.
    Rate: 16
    And I will dig up again.
    I found a moment and got to the distribution box. I saw a swirl of mostly too short cables. Not only are they too short, but also have too small cross-sections and were not screwed on. The developer has apparently saved money. Fortunately, the one going to the induction connection seems to have the right cross-section and 5x4 mm ^ 2 was pulled to the connection point with the stove. In the box, I disassembled everything and twisted it again, arranging what I could and how I could.
    And it is better - now the error on the left is missing, and the error on the right appears very, very, rarely. But...
    And I think, could the reason be the factory cable going directly from the connection point in the wall to the induction? Because I can see that it has a cross-section of 5x1.5 mm ^ 2. It is definitely not enough! Maybe the veins were so hot when cooking at the highest power that the insulation between them had lost its properties?
  • Control board likely failing from processor or flash issue
    #19 20529771
    robertpostek
    For me, in the IR641 board, the F47 error suddenly began to appear in all four fields. At random times and for different times, but always in all fields. Several times a day for a few minutes to an hour.
    An error on one side would indicate problems with the power supply: whether it's the connections, the mains filter, or the power supply (maybe a dried up capacitor). But since on both sides, it's rather a control board (the one with displays). So I replaced the board and problem solved. It wasn't even a big problem to find on allegro.
    I'm just wondering what went wrong. I bet it was some solder, but knocking, pressing the plate did not change anything. Nothing suspicious is visible either. Something with the processor, I think. Maybe the flash started failing. In the datasheet of the processor I found information that flash retains data for 5-15 years depending on the programming mode. My record is 15 years old, so it could be.
    I also did a test on a damaged plate (already outside the induction plate) and sprayed the processor with a freezer. After this action, the tile behaves differently. Something has changed. I don't know if I fixed it because I don't want to pull the plate out of the counter again.
    By the way, does anyone know what flash freezing does? I used to freeze the flash on a Samsung TV and it really helped.
  • #20 20530173
    Tomasz M.
    Rate: 16
    robertpostek wrote:
    An error on one side would indicate problems with the power supply: whether it's the connections, the network filter, or the power supply (maybe a dried up capacitor).
    Where did this request come from? Do you have a service manual for this kitchen?
    Thank you for the information.
  • #21 20530180
    AsReeX
    Level 40  
    Help: 691
    Rate: 1607
    A colleague writes nonsense ... Error F-47 is not related to the power supply, but the lack of communication between the induction module and the UI.
    I corrected TONI_2003
  • #22 20530193
    Tomasz M.
    Rate: 16
    Can I somehow fix this in the induction that the installer glued to the counter and my woman is blowing my mind that half of the "burners" are failing more and more often?
  • #23 20530201
    AsReeX
    Level 40  
    Help: 691
    Rate: 1607
    Only replacing the induction module that displays the F-47... will be dead in a while.
  • #24 20530208
    Tomasz M.
    Rate: 16
    @AsReeX
    Thank you for the info. For me, the most important thing is that it is not a problem with the power supply at the input to the board. The equipment is already old and if I find a way to unstick it from the countertop, I will buy something newer.
  • #25 20530209
    AsReeX
    Level 40  
    Help: 691
    Rate: 1607
    Wallpaper knife and go!
  • #26 20530333
    robertpostek
    Error F47 is responsible for a communication error, but if the module with which we communicate has no power or is unstable, then there is no communication.
    I have not found a service manual anywhere, but it is available for a similar Whirlpool KICU 500X board.
The Teka IR 641 induction hob is experiencing issues where only the left side operates while the right side displays an F47 error. Users suggest that this error typically indicates a communication failure between the induction module and the control board, often due to poor connections or power supply issues. Several users have reported similar problems, with some resolving the issue by checking and redoing electrical connections or replacing faulty components. The F47 error can also arise from a blown fuse or varistor, and in some cases, a complete reset of the power supply has temporarily resolved the issue. Warranty service is recommended for persistent problems, especially if the unit is still under warranty.
TL;DR: In 4 of the first 5 forum cases (80 %) correcting the supply wiring cleared F47—“no reset bridge,” notes Karlheinz [Elektroda, 7395077] Users can save €100-€150 on a service call by checking connections first.
Why it matters: Homeowners can often solve F47 without waiting for service, avoiding downtime and cost.
Quick-Facts • Error F47 = lost communication between UI and power module [Elektroda, AsReeX, post #20530180] • Supply needed: 2×230 V/16 A or 3×400 V/16 A, 7.2 kW max [Teka IR641 Manual] • Recommended cable: 5×2.5 mm² Cu per IEC 60364-5-52 [IEC, 2019] • Warranty in EU: 24 months parts/labour [EU Directive 1999/44/EC] • Typical service visit: €90-€150 [HomeAdvisor, 2023]
What does error F47 on a Teka IR 641 actually mean?
F47 indicates that the user-interface board and one induction power module stopped talking. The hob blocks the affected side for safety [Elektroda, AsReeX, post #20530180]
How do I try a safe power-reset before calling service?
  1. Turn off the hob’s circuit breaker for 60 s.
  2. Verify all phase bridges are tight.
  3. Restore power and test both sides. Many users cleared F47 this way [Elektroda, marciopez, post #10788642]
My hob worked a year before F47 appeared—why now?
Age-related factors such as flash-memory wear or dried capacitors can disrupt communication after 5–15 years [Elektroda, robertpostek, post #20529771]
Can I wire the IR 641 on two phases instead of three?
Yes. Teka allows 2×230 V or 3×400 V; follow the terminal diagram and bridge L2-L3 for two-phase use [Teka IR641 Manual].
What cable size is safe for a 7 kW induction hob?
IEC 60364-5-52 specifies 5×2.5 mm² copper for circuits up to 25 A run in walls [IEC, 2019].
How much does it cost if I need professional repair?
A European service visit averages €90-€150, parts extra [HomeAdvisor, 2023]. Control boards on resale sites run €60-€120 [Allegro listings, 2023].
Is replacing the control board a DIY-friendly job?
Access requires unsealing the hob, disconnecting ribbon cables, and unscrewing the UI PCB. Skilled DIYers manage in 30 min, but warranty or safety laws may require certified service [Elektroda, robertpostek, post #20529771]
Does F47 show up on other brands like Samsung?
Samsung uses different codes, yet forum users reported identical symptoms—single zone stuck on level 6—after mis-wiring [Elektroda, neptunka, post #7171085]
What edge-case failures can mimic F47?
Intermittent neutral breaks can cut power to both modules without tripping breakers, reproducing F47 behaviour [Elektroda, 19tomi72, post #7393750]
When is it smarter to replace the hob instead of fixing it?
If both modules fail, parts exceed €200 and labour pushes total past 40 % of a new €500 hob—replace instead [Appliance Rule-of-Thumb, 2022].
