BEKO HII 64401T - Half of the induction hob does not work, error E on the displa
obzejtka38 45090 5
  • #1 15450400
    obzejtka38
    Our three-year-old Beko board gave up halfway through - it didn't work on the left side. When it was turned on, the fuse blew, and now error E is displayed on the left side. We waited, turned off the fuse and still nothing.
  • #2 15450517
    ciasteczkowypotwor
    Help: 591
    Rate: 577
    @obzejtka38 The forum is full of fortune tellers, let's predict what this album is.
  • #3 15450522
    Piotr2608
    Help: 851
    Rate: 4488
    The power module is most likely damaged. We have the following variants:
    - disassemble the cooker, call Beko to order the module and replace it
    - call the service, a specialist for repair
    - try to repair the stove yourself
    Please provide the model of this induction cooker.
    ZimTech Piotr Zimny
  • #4 15450541
    obzejtka38
    This is a BEKO induction hob model HII 64401 t
    Added after 1 [minute]:
    BEKO hii 64401 plate
  • #5 15450658
    luk_jag
    Home appliances specialist
    Help: 67
    Rate: 257
    Photos of the inside are needed to give any hints
    Piotr2608
    Help: 851
    Rate: 4488
    Inductor Module - new price approx. PLN 700.
    One half of it is damaged.
    First of all, it would be worth checking the transistors on the heat sink. One pair will be damaged. The power fuse should be damaged.
    ZimTech Piotr Zimny
