[Solved] Win10 - Error code: 0x80070426 - Microsoft Security Client Error
3DH 8691 1
  • #1 16280233
    3DH
    Rate: 22
    I have had a problem with it before and it was enough to enter "wsreset.exe" in the "Run" window (Win + R). Unfortunately, I can't get rid of it that easily. I also don't have a restore point (not enough disk space). At this address I found several ways to fix this error:
    http://www.errorlive.com/error-code-0x80070426
    Unfortunately, I have a problem checking methods 2 and 5. In method 2, I am not sure of the Polish translation of "Software Licensing", and in 5 I cannot stop the "WinDefend" service in Task Manager (access denied).
    Thanks for the help.
    --- edit 1 ---
    In Control Panel (Win + I) I found "Troubleshooting". Later:
    System and security: Solve problems with Windows Update> ... found nothing ...> Try again as an administrator
    After repair and restart I didn't have this error anymore. I found a solution here . I don't know if it matters, but I've reset IE11 settings before.
    --- edit 2 ---
    Every now and then the error returns, but this time I tried a different way ( source ):
    Win + X> Command line (administrator)> paste this:
    sfc / scannow
    If the scan did not detect anything, then paste it:
    dism.exe / online / cleanup-image / scanhealth
    dism.exe / online / cleanup-image / restorehealth
    After restarting, Windows Defender should start normally.
  • #2 17243405
    3DH
    Rate: 22
    The USB ports proved to be a problem, more precisely their "standby" after off / on. computer. After turning off the USB power in the BIOS:
    Power> Deep Sleep S5 support
    I have not seen these errors anymore.
