  • DataExchange.dll errors affecting multiple programs
    #1 19837714
    MajerM
    Hi.
    Could you please help me with my friend's problem?
    A similar error with the DataExchange.dll file appears with many programs and it seems that the situation is getting worse, at the beginning it was only with Adobe Reader, but reinstalling, changing the version or other combinations did not help.
    I am attaching a scan from FRST.
    Separated from the topic: Windows 10 Error: 0xc000012f
    by Dra98 on 23 Jan 2022 1:01 pm
    • Windows 10 Error: 0xc000012f image_2022_01_23T10_16_54_561Z.png (17.01 KB) You must be logged in to download this attachment.
    • Search.txt (4.54 KB) You must be logged in to download this attachment.
    • Windows 10 Error: 0xc000012f image_2022_01_23T10_15_55_896Z.png (33.32 KB) You must be logged in to download this attachment.
    • Windows 10 Error: 0xc000012f image_2021_12_27T21_09_18_324Z.png (14.15 KB) You must be logged in to download this attachment.
    • FRST.txt (46.37 KB) You must be logged in to download this attachment.
    • Addition.txt (55.21 KB) You must be logged in to download this attachment.
  • McAfee removal and SysWOW64 DataExchange.dll replacement
    #2 19837778
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    @MajerM uninstall McAfee LiveSafe.
    Fixlist.txt cosmetic:
    HKLM-x32 \ ... \ Run: [SunJavaUpdateSched] => C: \ Program Files (x86) \ Common Files \ Java \ Java Update \ jusched.exe [710264 2020-06-18] (Oracle America, Inc. - > Oracle Corporation)
    HKLM-x32 \ ... \ Run: [] => [X]
    HKU \ S-1-5-21-3830351947-1260378648-2156389229-1001 \ ... \ Run: [Opera Browser Assistant] => C: \ Users \ mmusi \ AppData \ Local \ Programs \ Opera \ assistant \ browser_assistant. exe [4105424 2021-10-14] (Opera Software AS -> Opera Software)
    Task: {4CF41F46-6744-4BDD-813D-233F737589DB} - System32 \ Tasks \ Opera scheduled assistant Autoupdate 1603711362 => C: \ Users \ mmusi \ AppData \ Local \ Programs \ Opera \ launcher.exe [2256592 2022-01-12 ] (Opera Software AS -> Opera Software) -> --scheduledautoupdate --component-name = assistant --component-path = "C: \ Users \ mmusi \ AppData \ Local \ Programs \ Opera \ assistant" $ (Arg0)
    Task: {CDD9C89F-010C-452F-9C59-161E22485C6C} - System32 \ Tasks \ Opera scheduled Autoupdate 1603711358 => C: \ Users \ mmusi \ AppData \ Local \ Programs \ Opera \ launcher.exe [2256592 2022-01-12] (Opera Software AS -> Opera Software)
    Strange, the file looks correct:
    C: \ Windows \ System32 \ DataExchange.dll
    [2020-10-22 18:31] [2020-10-22 18:31] 000237056 _____ (Microsoft Corporation) 68EC90573D01A407FBFB4C98B831F9CF [Digitally signed file]
    For the damaged one:
    C: \ Windows \ SysWOW64 \ DataExchange.dll
    [2020-10-22 18:32] [2020-10-22 18:32] 000184320 _____ () 3FE7308E6EF0E6263D5587918B8410C2 [No digital signature]
    Extract the file from the attachment to C: and execute Fixlist.txt:
    Copy: C: \ Windows \ SysWOW64 \ DataExchange.dll C: \ Windows \ SysWOW64 \ DataExchange.bck
    Replace: C: \ DataExchange.dll C: \ Windows \ SysWOW64 \ DataExchange.dll
    After rebooting, check to see if anything has changed. If not, you can replace the system32 file, but it's a different one and I will give it later as needed.
    Alternatively, you can also check the command: DISM / Online / Cleanup-Image / CheckHealth
    Run in a cmd window running with administrator rights.
    • DataExchange.zip (84.9 KB) You must be logged in to download this attachment.
  • #3 19838068
    MajerM
    Thanks a lot for your help @Kolobos .
    Problem solved thanks to your advice.
  • #4 19849323
    RADU23
    Help: 2428
    Rate: 1732
    Delete the C: \ FRST folder and that's it.
