Audi A4 B7: BRAKE LIGHT Message - Brems Licht, Stop Lamps, Bulb Replacement & License Plate Light
arkadziej4 107427 8
  • #1 16280302
    arkadziej4
    Rate: 21
    Hello, for some time I see the message "brems licht" applies to stop lamps. All stop lights are (3) all glow properly. I replaced some bulbs of the license plate light some time ago and they do not have these resistors and an error is displayed that they are burned. Can it have something to do? I will add that I replaced the light bulb a month ago, and the message has been showing up for a week.
  • #2 16280433
    2323wojtek
    Help: 29
    Rate: 84
    Write when you get this message, I have a message with me as soon as I turn on the ignition but after pressing on the brake pedal the message disappears. Is it similar to you or is it always lit up?
  • #3 16280475
    arkadziej4
    Rate: 21
    the message is displayed immediately after switching on the ignition and burns all the time regardless of pressure on the pedal or not.
  • #4 16280680
  • #5 16281040
    2323wojtek
    Help: 29
    Rate: 84
    I had a case like yours, I also received such a message. It turned out that one (filament) bulb had one fiber burned and that was the reason for this message. Check the bulbs, replace first and then the second one and see if it helped.
  • #6 16296675
    arkadziej4
    Rate: 21
    Gentlemen, I replaced all the bulbs in the two rear lamps and nothing, the mistake of stopping is still burning. I replaced the license plate bulbs and I still get a message that burned ...
    What can he go about?
  • #7 16296679
    jerrydzwonkow
    Rate: 18
    Podcz your computer and you will have info which exactly a light bulb or lamp is a problem
  • #8 16296688
    arkadziej4
    Rate: 21
    Well, it probably will be necessary
  • #9 19494169
    DominikKozuchowski
    Hello, I had it, it turned out that the cube in the LED strip in the pit loosened, I unscrewed the plastics, I improved the cube and it's ok ?
The discussion revolves around an Audi A4 B7 owner's persistent "brems licht" warning related to stop lamps, despite all bulbs functioning correctly. The user replaced the license plate bulbs previously, which lacked resistors, potentially causing the error message. Other participants shared similar experiences, suggesting that a burned filament in a bulb could trigger the warning. Recommendations included checking all bulbs, replacing them if necessary, and using a diagnostic tool to identify specific faulty components. One user noted that a loose connection in an LED strip resolved their issue.
