Passat B5 1997 1.9 90km Stop Lights Not Working: Bulbs Checked, Sensor Replaced, Rear Lamp Damage
mariusz169 11544 4
  • Rear lamp damage may have broken the brake light circuit
    #1 16513722
    mariusz169
    Hello, I have Passat B5 1997. 1.9 90km, namely I have a problem with the lack of all the stop lights, the bulbs checked, the sensor replaced and nothing, I will add that when the plug plugs all the foot candle, I know that new parts can also be broken, so I checked the new sensor at a friend in the same passat and the sensor is OKAY. I will add that about two weeks ago I had a delicate bump and the rear left lamp was slightly damaged (exactly the shade, the cartridge seems to be ok), is it possible that something got mixed up in the lamp when I hit it, so to speak? As for the fuses, with a bridged cube of light they shine, so it's not him, because I do not bypass him in this way.
  • #2 16513735
    andrzej20001
    Help: 1578
    Rate: 6668
    Trash sensor. Buy Eps such a green square.
  • #3 16513809
    Ireneo
    Help: 747
    Rate: 2469
    Also pay attention to the correct installation.
  • #4 16513816
    Staszek49
    Help: 228
    Rate: 1140
    Buy the correct "stop" light switch and pay attention to its correct installation. It is quite a delicate device and is easy to damage when worn. A description of the above can be found on the forum.
    Damaged above switch (e.g. Golf IV, similar in Passat b5) and a blown fuse from the brake light is indicated by the glow plug heating lamp, however, each of these faults is slightly different.
    In the past I came across a new switch damaged, but after demolition and repair it still serves me.
  • #5 16514079
    andrzej20001
    Help: 1578
    Rate: 6668
    You turn it on the RELEASED brake pedal. EPS from experience is best years from budgetary. Passat B5 1997 1.9 90km Stop Lights Not Working: Bulbs Checked, Sensor Replaced, Rear Lamp Damage
