Telefunken LED TV D32H278R3: Replacing 17MB82 Motherboard with D32H278A3 - Upside Down Image
MartinBth 14640 7
  • #1 16281561
    MartinBth
    Rate: 15
    i am new in this Forum.I am from Germany.My Problem:
    I have an Telefunken LED TV Model: D32H278R3
    The Motherboard Vester 17MB82 is broken.
    I buy on Ebay an other Board from an Telefunken D32H278A3.
    Now the Picture ist standing on the Head and the Picture ist very Bad.
    Motherboard: 17MB82S
    Power Supply:17IPS71
    Panel:VES315WNDL-2D-N02
    Here some Picture from the TV.
    Ok,it is not the right T-CON Board.Does the right T-CON board work with the VES315WNDL-2D-N02 panel?
    In the service menu one can make some settings but panel does not select. A little at the color and sound.
    An update via USB does not go.USB Stick is detected. File does not go (08_nolu_yazilim_V.084/upgrade_loader.pkg)
    Wong Software?
    A USB log I could make(USB trace.log).
    Or I sell everything back on Ebay.
    I do not know what's wrong with the old board.
    CPU? RAM? Flash?
    Is the Software in the Winbond Chips ?
    Can i flash the Winbond Chips ?
    What can i do?
    Who can help me,please ?
    Greetings from Germany
    Martin
    • wakeup_reasons.txt (409 Bytes) You must be logged in to download this attachment.
    • usb_trace_.txt (7.42 KB) You must be logged in to download this attachment.
    • Telefunken LED TV D32H278R3: Replacing 17MB82 Motherboard with D32H278A3 - Upside Down Image DSC05413.jpg (841.79 KB) You must be logged in to download this attachment.
    • Telefunken LED TV D32H278R3: Replacing 17MB82 Motherboard with D32H278A3 - Upside Down Image DSC05420.jpg (686.03 KB) You must be logged in to download this attachment.
    • Telefunken LED TV D32H278R3: Replacing 17MB82 Motherboard with D32H278A3 - Upside Down Image DSC05412.jpg (979.5 KB) You must be logged in to download this attachment.
    • Telefunken LED TV D32H278R3: Replacing 17MB82 Motherboard with D32H278A3 - Upside Down Image DSC05394.JPG (1.26 MB) You must be logged in to download this attachment.
    • Telefunken LED TV D32H278R3: Replacing 17MB82 Motherboard with D32H278A3 - Upside Down Image DSC05410.jpg (571.73 KB) You must be logged in to download this attachment.
    • Telefunken LED TV D32H278R3: Replacing 17MB82 Motherboard with D32H278A3 - Upside Down Image DSC05411.jpg (696.63 KB) You must be logged in to download this attachment.
  • #2 16282403
    elmo071
    Level 30  
    Help: 167
    Rate: 801
    Maybe one bin. will be good, the same panel what yours
    1.
    Telefunken D32H125N2
    17MB82-2 Vestel
    MT5820LUNU
    25QH16_u10
    25QH64_u12
    Panel: VES315WNDB-01
    2.
    Telefunken D32H127N2
    17MB82-1a
    MT5820LUNU
    U10 cFeon QH16
    U12 cFeon Q64
    Moderated By MOD:
    • 27703_Telefunken_D32H.rar (9.62 MB) You must be logged in to download this attachment.
    • 38137_TelefunkenD32H1.rar (9.68 MB) You must be logged in to download this attachment.
  • #3 16282414
    MartinBth
    Rate: 15
    Hi,thank you but U10 is a 25Q32FVSIG and the U12 is a 25Q64VFSIG.
    Can I still take the files?
    CU-Martin
  • #4 16284448
    GeMas
    CU-Martin
    Hi, Martin!
    Please upload here dump of U10/U12 (25Q32 & 25Q64) of your matherboard. I want compare the contents with other firmware.I have now the same model - Telefunken D32H278KT3
    Genady
  • #5 16284776
    MartinBth
    Rate: 15
    I can only start in 4-5 days.
  • #6 16287602
    MartinBth
    Rate: 15
    Hooray ,
    my TV works again.I solder the old(from D32H278R3) Winbond Chips to the other Board(R32H278A3).Before I soldered I created a dump from the Chips.With Raspberry and Flashron Software.I have wrote new Winbonds and solder it but it works not.I think the CPU from the old Board is dead.Or not?I wrote the new Chips with Images/Dumps from a Polish Board.The Size was correct.
    When anywone needs my Dumps(D32H278R3 and R32H278A3) can i post it.
    Ok,see you next Time
    Martin
    • Telefunken LED TV D32H278R3: Replacing 17MB82 Motherboard with D32H278A3 - Upside Down Image DSC05467.jpg (733.14 KB) You must be logged in to download this attachment.
    • Telefunken LED TV D32H278R3: Replacing 17MB82 Motherboard with D32H278A3 - Upside Down Image DSC05457.jpg (496.93 KB) You must be logged in to download this attachment.
    • Telefunken LED TV D32H278R3: Replacing 17MB82 Motherboard with D32H278A3 - Upside Down Image DSC05445.jpg (613.55 KB) You must be logged in to download this attachment.
    • Telefunken LED TV D32H278R3: Replacing 17MB82 Motherboard with D32H278A3 - Upside Down Image DSC05439.jpg (605.85 KB) You must be logged in to download this attachment.
    • Telefunken LED TV D32H278R3: Replacing 17MB82 Motherboard with D32H278A3 - Upside Down Image DSC05435.jpg (458.52 KB) You must be logged in to download this attachment.
    • Telefunken LED TV D32H278R3: Replacing 17MB82 Motherboard with D32H278A3 - Upside Down Image DSC05431.jpg (551.43 KB) You must be logged in to download this attachment.
    • Telefunken LED TV D32H278R3: Replacing 17MB82 Motherboard with D32H278A3 - Upside Down Image DSC05426.jpg (562.83 KB) You must be logged in to download this attachment.
    • Telefunken LED TV D32H278R3: Replacing 17MB82 Motherboard with D32H278A3 - Upside Down Image DSC05425.jpg (598.93 KB) You must be logged in to download this attachment.
    • Telefunken LED TV D32H278R3: Replacing 17MB82 Motherboard with D32H278A3 - Upside Down Image DSC05422.jpg (623.5 KB) You must be logged in to download this attachment.
  • #7 16287608
    MartinBth
    Rate: 15
    The Dumps are here.Size must be correct.For W25Q32 and W25Q64
    • D32H278R3.rar (9.27 MB) You must be logged in to download this attachment.
    • D32H278A3.rar (9.28 MB) You must be logged in to download this attachment.
  • #8 16293760
    GeMas
    Very good! Thank you very match!
    Best regards
    Genady
The discussion revolves around a user from Germany who is attempting to replace a broken motherboard (17MB82) in a Telefunken LED TV model D32H278R3 with a different board from model D32H278A3. After the replacement, the user experiences an upside-down image and poor picture quality. The user suspects the T-CON board is incompatible and seeks advice on whether the correct T-CON board would work with the existing panel (VES315WNDL-2D-N02). The conversation includes suggestions to upload firmware dumps from the Winbond chips for comparison, and ultimately, the user successfully resolves the issue by soldering the original Winbond chips onto the new board, although they suspect the CPU from the old board may be defective. The user offers to share the firmware dumps for others facing similar issues.
