iPhone 6 WiFi Connection Issue: Incorrect Password Despite Correct Input & Reset Solutions
fuuubi 3684 3
  • #1 16281720
    fuuubi
    Hello, I bought an iPhone 6, the stimulant was cleaned, when I connect to the wifi, I enter the correct password and say that the password is incorrect. I was updating the soft and cleaning the wifi settings. What to do, help.
  • Replace the iPhone 6 Wi‑Fi module after software checks
    #2 16282080
    gsmowiec
    User under supervision
    Help: 27
    Rate: 128
    I had such a case in the five it turned out that the wifi module was to be replaced.
    In this case, first for diagnosis, the system with its elements (in the diagram u5201_rf)
    If the seller did not inform you about this fault, just file a complaint and send it back with a request for a refund or repair of the fault.
    • iPhone_6_Schematic_Diagram.pdf (3.77 MB) You must be logged in to download this attachment.
  • #3 16285212
    venummasa
    Level 19  
    Help: 28
    Rate: 69
    It also triggers a message such as poor wifi coverage
  • #4 16287199
    fang13
    The same may be true if you are using some VPN apps
