Outlander 2.0did - Lights Leveling Error: B2512 Driver Range Adjustment, EEPROM Issue, Cold Battery
brzozayz 8001 4
  • #1 16286568
    brzozayz
    Rate: 137
    Hello, I have a problem with the leveling of lights display the message on the board. After connecting the tester there were two errors, one could be removed but the other returns after a while it is B2512 Driver the range adjustment of lights Error in EEPROM. It happened in the cold after discharging the battery, please help, greetings.
    bsv2001
    Help: 26
    Rate: 183
    change the headlight range control driver or look for EEPROM from another driver
    Problem in CHECKSUM EEPROM
    coach
    Rate: 27
    Buy a stimulant and by topic :)
  • #4 16287373
    brzozayz
    Rate: 137
    Do you know where he is and do you need to adopt him?
    Ireneo
    Help: 747
    Rate: 2474
    You do not need to adapt and it is probably behind the passenger compartment, somehow on the right on the pillar.
