Wood Soda Blasting Equipment: Best Gun, Compressor Models & Granulation for Private Use
SylwiaD-P 36969 17
What gun, compressor and soda granulation should I use for DIY wood soda blasting?
There is no clearly recommended cheap model, but for wood cleaning the replies point to sodium bicarbonate (NaHCO3) soda in a gun with a hopper/container, not caustic soda [#17085768][#17087100] The soda should be dry and fine, around 0.1–0.3 mm, because hygroscopic soda clogs the nozzle and the material is light, so it needs high air speed to remove old coatings [#17085768] A small home compressor is a bad match: one reply says a 50 l tank with a simple single-cylinder oil compressor will not run continuously, and another reports a 50 l compressor being damaged when feeding a 65 l siphon blaster [#17087100][#17084968] For occasional private use, several replies suggest renting a larger compressor or hiring a company, because proper soda-blasting equipment is very expensive [#17085821][#17085856]
  • #1 17084904
    SylwiaD-P
    One movie on piped up for me, where I saw a guy sow wood and walk unconscious in the morning. I tire with grinders, heaters, and abrasives, and this old wood and wood is clean. I decided to make my life easier and buy the right equipment ... and here the stairs start for me, therefore I am asking for help. I will mention that it does not have to be mega-busted and expensive equipment. It's for my private needs. I arrange a hut, buy lumber and renew it. I know the pistol, compressor, protective clothing. Would anyone nice and familiar with the subject could give me a specific model of the gun and compressor. How much does it have to have bars? What soda granulation is required for wood cleaning? Please help.
  • #2 17084968
    yanes
    Help: 206
    Rate: 601
    My boss probably watched this video too, because he bought 10 bags of this: link
    Soda Blasting average 0.1-0.3 mm - PROFESSIONAL TRIM FOR SODING
    they lie against the wall in the workshop.
    He bought a sandblaster like this:
    65L SIPHON CEILING FREE SCREEN WITH VACUUM CLEANER
    link and the 50 liter compressor was long ago. The finale, one soda bag poured into the 'sandblaster', the compressor damaged and everything stood still.
  • #3 17085091
    mladenick
    Help: 14
    Rate: 90
    I do not know if it will be good for you, because you have to have a sandblaster (about 1000 PLN) And the compressor is this https://www.olx.pl/oferta/kompresor-srubowy-spalinowy-compair-c38-sprezarka-przewozna-04r- CID619-IDqrRjL.html # 07c4c744c6 may not move, we always rented the largest one available, I think it's cheaper to look for someone who comes with the equipment and will do it for you.
  • #4 17085617
    SylwiaD-P
    It was some company dealing in the soda of car body, but they took orders for sodding furniture. Hmmm ... I'm a bit broken. I thought I would just buy this gun, a compressor and I will paint paints and varnishes from furniture :-(
    In the meantime, I read somewhere that the gun should have a container where it is poured into the cloth so I probably do not necessarily have to have a sandblaster? Do I have to ? Someone also wrote that he has a gun without a container, puts a hose in a bucket of cleaners and at 11 bars he goes perfectly ... I have already stupid to the rest.
  • #5 17085708
    Krzysztof Kamienski
    Help: 2032
    Rate: 5155
    SylwiaD-P wrote:
    I've been stupid to the rest.
    And it's good that you were stupid :D because maybe you can see the beautiful world in your own eyes :!: . Spraying a caustic soda solution (NaOH) with spray gun is obvious idiocy, straight from You Tube. A concentrated sodium hydroxide solution is applied to the object only using a paint brush or roller, using - safety goggles and rubber gloves as a minimum protection.
    Alternative chemist ??? :D
  • #6 17085768
  • #7 17085821
    mychaj
    Help: 214
    Rate: 939
    You could try something like this: these are photos from the thread about compressors link
    posts # 5041 # 5047.
    Wood Soda Blasting Equipment: Best Gun, Compressor Models & Granulation for Private Use Wood Soda Blasting Equipment: Best Gun, Compressor Models & Granulation for Private Use Wood Soda Blasting Equipment: Best Gun, Compressor Models & Granulation for Private Use
    And a compressor - maybe from a construction equipment rental company? At least for a try, you'll see how it goes.
  • #8 17085856
    Pablo905
    Hello. Art.B is right, it is baking soda, but unfortunately you need the right equipment, the cheapest one I was interested in, this expenditure of PLN 32000. So it probably falls off. Sandblasting of wood is associated with almost some damage to the cleaned surfaces. If for occasional use for my own needs, in my opinion this third of the above photos.
    He was recently available at Lidl for maybe PLN 70. The compressor is worth buying, it is always useful at home. In supermarkets on promo. you can hit for 300. / for home use /. You can replace it with sand from the market / you have to check in to describe what gradation /
    The whole should be closed in the amount of PLN 500. Apot by trial and error. Everything you buy can be used for other purposes, so the loss will not be.
  • #9 17085882
    Strumien swiadomosci swia
    Help: 1403
    Rate: 6398
    Krzysztof Kamienski wrote:
    The concentrated sodium hydroxide solution is applied to the object only with a brush or roller
    And in addition it works, it goes away layer by layer.
  • #10 17087013
    Krzysztof Kamienski
    Help: 2032
    Rate: 5155
    Art.B wrote:
    Normally sodium bicarbonate (NaHCO3) is used for soda
    After all, this chemical compound is neutral to metals. Why should you treat it? :cry: Reacts violently with acids, emitting CO2.
  • #11 17087052
  • #12 17087100
    tzok
    Help: 3162
    Rate: 6462
    It is used as abrasive for sanding delicate surfaces (aluminum, wood).
    You can sand such a gun with a container, but the compressor must have a minimum tank of 50l, and with a simple, single-cylinder oil compressor, there is no question of continuous operation.
  • #13 17087405
    SylwiaD-P
    Thank you for all the comments. Maybe, actually, I will look for someone nearby who is sandblasting, because I have acquired a large sideboard with many details and it will be difficult to deal with it. greetings :-)
  • #14 17088775
    artwa
    Help: 6
    Rate: 8
    Not about the compressor, but about NaOH:
    I cleaned the old furniture (chairs) with NaOH solution (about 10-20% by volume in water in a 0.5-1l jar, which was waiting for the next use). I applied it with a brush (necessarily artificial bristles, and at the washing of a plastic bucket) and waited until it clearly softened everything - a few dozen minutes in a cool cellar; if I did not have a given day of time, collect the dissolved layer, I wrapped it in a stretch foil. Then a sponge and water or a spatula (flat surfaces) to wash or collect the resulting "pudding" of the dissolved layer. Sometimes I soaked with water again if I did not have any more time and the element dried out (I worked in the friend's cellar at night). At the end repeatedly or several times washing with a sponge with a change of water. However, this did not remove the yellowish color that I found under the paint and was soaked in wood to a depth of about 0.5-1mm. But just this yellow residue later facilitated the application of varnish.
    A carpenter selling refurbished "antiques" told me that he uses perhydrol for old coatings (eg polish).
    A little (but not everything) about security:
    When playing with soda (NaOH) I used thicker rubber gloves and tight protective goggles (goggles, not ordinary glasses), ordinary clothing covering the body (long sleeves, long pants). And I always had with me a bottle of vinegar and water in case of skin contact with NaOH, garbage bags, cloths ... NaOH solution never burned me right away - if you wash quickly and abundantly, it's rather difficult to get these nasty burns. Only eyes must be ruthlessly watched.
    It was a little faster than mechanical removal and at most the floor was dirtied, it did not dust. Quite cheap - probably PLN 10 costs 1 kg of NaOH in granules.
    In this work, of course, it is worth to consider at the outset: how to pour water in gloves sapbed in sodium, where I put away dirty tools, clothes, etc., not to know after a few minutes that we "smoke" somewhere in the clothing or hand is burned; which is clean and what we treat as dirty with NaOH solution and we do not touch without gloves. If the soda would then drip onto the lawn or other plants, it is worth to say goodbye to them. In addition, I recommend reading with what the NaOH solution (metals, organic materials) reacts to use a non-reactive vessel or tool. Plastics and glass - "that's it!"
    Direct combination of vinegar and soda in larger quantities surely results in a rather dangerous geyser.
    NaOH certainly will not violate contemporary acrylic paint - I fought with it mechanically.
  • #15 17088897
    Help: 1403
    Rate: 6398
    First, the skin becomes soft and slippery, then it goes off by itself.
  • #16 17088998
    artwa
    Help: 6
    Rate: 8
    My point was that quick action at small amounts saved the situation. Once I washed the balcony with soda and then neglect (I knelt on the washed floor) appeared after some time, because I did not wash my knees - skin going down and unpleasant depilation.
  • #17 17089663
    Sofeicz
    Help: 12
    Rate: 123
    You can always figure out something or ask for a golden handle.
    Full of that on YT, just enter "Soda blasting diy".
    For a Soda Blaster professional pistol you will pay PLN 56,000 (net).
  • #18 17094185
    SylwiaD-P
    Thank you for good and kind advice :-) I did not think that mechanical sodding was such a complicated and expensive matter. By the way, I learned a lot of new and useful things for me that will definitely be useful to me in the future. I greet you all :-)
✨ The discussion revolves around selecting appropriate wood soda blasting equipment for private use, focusing on the necessary gun, compressor models, and soda granulation. Users share experiences and recommendations, highlighting the importance of using sodium bicarbonate (baking soda) as a non-toxic abrasive. A minimum compressor tank size of 50 liters is suggested for effective operation, with some users recommending renting equipment for occasional use. Various models and brands are mentioned, along with the potential for DIY solutions. Concerns about the effectiveness and safety of different cleaning methods, including the use of caustic soda, are also addressed.
TL;DR: For DIY wood soda blasting, equipment matters: a 50 L compressor failed mid‑job; "the compressor damaged and everything stood still." This FAQ helps DIYers choose guns, compressors, granulation, and safer alternatives. [Elektroda, yanes, post #17084968]
Why it matters: Picking the right gun, compressor, and media prevents clogging, damage to wood, and expensive dead-ends for private projects.
Which media should I use for wood soda blasting—bicarbonate or lye?
Use sodium bicarbonate (NaHCO3), not sodium hydroxide (NaOH). Bicarbonate is low‑toxicity, water‑soluble, and gentle on surfaces. It is hygroscopic, so keep it dry to avoid clogging. Because soda is soft and light, you need higher air velocity than with sand to cut coatings. "An interesting option is also sandblasting grounded CO2 (dry ice)." Consider it if soda underperforms. [Elektroda, Anonymous, post #17085768]
What soda granulation works best for cleaning wood furniture?
For wood, use blasting soda around 0.1–0.3 mm. This grade balances surface friendliness with enough bite to lift finishes. Pair it with a nozzle sized for light media and keep the stream moving to avoid fiber raising. Store the bags sealed to reduce moisture pickup and clogging. [Elektroda, yanes, post #17084968]
What compressor specs do I need to run a soda blasting gun at home?
Plan on at least a 50 L tank. A simple single‑cylinder oil compressor cannot sustain continuous blasting. Expect short duty cycles and pauses for recovery. For larger jobs, you will wait for pressure to catch up. If you need uninterrupted flow, rent a bigger unit. [Elektroda, tzok, post #17087100]
Can I run a siphon gun from a bucket at 11 bar?
One user reported a setup with a gun, no hopper, and the pickup hose in a bucket at 11 bar. Results vary by compressor airflow, hose length, and media dryness. Test carefully in a controlled area and watch for clogging from humid soda. [Elektroda, SylwiaD-P, post #17085617]
Do I need a dedicated sandblaster cabinet, or will a hopper gun work?
You can blast with a gun that has a media container. The limiting factor is air supply. A small, single‑cylinder compressor will not support continuous blasting. For quick, spot work it is fine. For furniture‑scale jobs, plan breaks or rent more air. [Elektroda, tzok, post #17087100]
Should I rent a large construction compressor to try soda blasting?
Yes, for trials it’s practical to rent the largest compressor available. "I think it's cheaper to look for someone who comes with the equipment and will do it for you." Price out rental vs. hiring a service for your project size. [Elektroda, mladenick, post #17085091]
Will soda blasting damage wood details and carvings?
Soda is suitable for delicate surfaces like aluminum and wood. Keep pressure, stand‑off distance, and dwell time conservative on carvings. "It is used as abrasive for sanding delicate surfaces (aluminum, wood)." Always test on an inconspicuous area first. [Elektroda, tzok, post #17087100]
What goes wrong with a small 50 L compressor when blasting?
A real‑world case: 10 bags of soda were bought, but a 50 L compressor failed during the first bag. "The compressor damaged and everything stood still." Small tanks and limited duty cycles can stall projects and waste media. [Elektroda, yanes, post #17084968]
How do I strip paint from wood using NaOH safely?
Use a brush-on method, not spraying. Try this:
  1. Mix ~10–20% NaOH in water; apply with a brush on wood in a cool area.
  2. Wait until the finish softens; wrap in film if pausing; scrape or sponge off the "pudding."
  3. Rinse multiple times with clean water; wear goggles and thick gloves; keep vinegar and water ready. NaOH may not pull deep stains. [Elektroda, artwa, post #17088775]
Why shouldn’t I spray NaOH with a gun?
"Spraying a caustic soda solution (NaOH) with spray gun is obvious idiocy." Apply only with a brush or roller. Wear safety goggles and rubber gloves as minimum PPE. Keep people and pets away. Dispose of residues responsibly. [Elektroda, Krzysztof Kamienski, post #17085708]
Is sodium bicarbonate chemically safe around metal hardware?
Yes. Sodium bicarbonate is neutral to metals and does not attack them. Keep it away from acids, as it reacts and releases CO2. Rinse metal parts after blasting to remove residues before refinishing or reassembly. Dry thoroughly to prevent flash rust on bare steel. [Elektroda, Krzysztof Kamienski, post #17087013]
Is dry‑ice blasting a better alternative for wood or moldy surfaces?
Dry ice impacts, then sublimates, which helps detach coatings without wet mess. "It is better to clean with solid CO2." It impressed users in mold remediation with sensitive shelving where chemicals were unsuitable. Availability and rental costs vary by region. [Elektroda, Anonymous, post #17087052]
How much does a budget DIY blasting setup cost?
A simple path: a low‑cost blasting gun (e.g., a promo unit from Lidl) and a promo compressor. Expect around 500 PLN total. This suits light, occasional tasks and experimentation. Start small, then scale if results meet your needs. [Elektroda, Pablo905, post #17085856]
How much does a professional soda blasting pistol cost?
A professional soda blaster pistol can cost about 56,000 PLN net. Consider total system needs too: high‑flow compressor, moisture control, and media handling. Weigh that against hiring a specialist for occasional furniture work. [Elektroda, Sofeicz, post #17089663]
Is it smarter to hire a pro instead of buying gear for one project?
For one‑off furniture or a large, detailed sideboard, hiring can be cheaper and faster. A pro arrives with the right blaster, airflow, and media. "Look for someone who comes with the equipment and will do it for you." Get quotes before buying. [Elektroda, mladenick, post #17085091]
Can NaOH remove modern acrylic paint from wood?
Not reliably. A user reported NaOH did not affect contemporary acrylics, requiring mechanical removal instead. Use scrapers, sanding, or soda for topcoats, then refinish. Always rinse and neutralize after chemical stripping before sanding to protect the wood. [Elektroda, artwa, post #17088775]
Can I use sand instead of soda on wood?
You can use sand with a low‑cost setup, but sandblasting wood risks surface damage and raised grain. If you try it, confirm the sand gradation and test on scrap. Many DIYers prefer soda for gentler action on furniture. [Elektroda, Pablo905, post #17085856]
