HUAWEI P8 Camera Focus Issue: How to Fix? Hard Reset or Hardware Fault? All Apps Affected
Lukasx97_ESP 7383 3
  • #1 16288705
    Lukasx97_ESP
    As in the subject. The camera is good for nothing. It is not possible to take a picture of the text on a piece of paper to make it readable. The guarantee does not apply because I have a cracked display. The problem is in each application, i.e. snapchat as well as in the system camera. Can you do something about it ?? Try hard reset or is it rather a hardware fault and not a software and it will not help?
    Thank you in advance
  • #2 16288932
    KamGr
    Help: 77
    Rate: 203
    You can try to make a hard reset, but as you write it can not give anything. You will probably need to replace the camera in this case.
  • #3 16290143
    saperx
    Help: 54
    Rate: 24
    Write what repair effect because I have the same patient on the site :)
  • #4 16302072
    Simek1982
    Rate: 24
    I had 3 such in two cameras in one scratched slide in the back casing.
