Huawei p8 lite - The phone resets after installing Android 6.0
Berreto26 4401 13
How can I stop a Huawei P8 Lite from resetting after an automatic Android 6.0 update?
The phone was not actually fixed by Android software changes; in the end, removing part of the magnetic case stopped the resets, and the phone worked normally in a rubber cover [#16969108] Before that, the recommended troubleshooting was to do a hard reset after the OTA update [#16324991][#16325288][#16326361] If the reset does not help, reinstall the firmware again [#16326361] The firmware can be installed from an SD card by copying the `dload` folder to the card and starting the update with Vol+, Vol-, and Power while the phone is off [#16944193] HiSuite install did not work in this case [#16944982]
  • #1 16324098
    Berreto26
    As in the title, I ask for advice.
  • #3 16324991
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    You did a hard reset, if not do it.
  • #4 16325288
    beo
    Level 37  
    Help: 298
    Rate: 238
    @ Berreto26 if upgrading via OTA, it's definitely a hard reset as a colleague above advises. If you uploaded the rom in a different way, write in what.
  • #5 16325662
    Berreto26
    Automatic update came and installed and since then resets. I did not upload anything myself, the future android update I clicked ok and from now on it is
  • #6 16326361
    nutergsm
    Help: 1034
    Rate: 1665
    Do this hard reset as colleagues write. If this does not help, you need to reinstall the software.
  • #7 16940235
    Berreto26
    Hello hard reset, nothing could be turned off while loading most often.
  • #8 16940705
    nutergsm
    Help: 1034
    Rate: 1665
    Then upload the firmware again.
  • #9 16944066
    Berreto26
    How to do the original soft from + Nothing was done.
  • #10 16944193
    nutergsm
    Help: 1034
    Rate: 1665
    Choose your model and download files http://consumer.huawei.com/pl/support/phones/p8-lite/
    Copy the dload folder to the SD card and the Vol +, Vol -, Power combination (on the phone off) enable the update.
    Or use the method that is in the # 2 post of this topic.
  • #11 16944982
    Berreto26
    HiSuite is not going to click install so it gives up on this thing. I won't buy this company anymore. Thank you for your help and best regards
  • #12 16945158
    nutergsm
    Help: 1034
    Rate: 1665
    You have to install from SD card.
  • #13 16945379
    Berreto26
    * # * # 2846579 # * # * Such code and Software Upgrade. That's how I found EMUI 4.0 C22B577 from
    Added after 4 [minutes]:
    I will write about the effects and I will thank you for your help. Regards.
  • #14 16969108
    Berreto26
    After detaching part of the magnet case, the phone works. The phone in the rubber cover does not reset works as it should. Thank you for your help, I'm closing.
The discussion revolves around issues faced by users of the Huawei P8 Lite after upgrading to Android 6.0, specifically the phone resetting unexpectedly. Users suggest performing a hard reset as a potential solution, especially if the upgrade was done via OTA (Over-The-Air). If the hard reset does not resolve the issue, reinstalling the firmware is recommended. Instructions for reinstalling the original software include downloading the appropriate files from Huawei's support site, placing them in a dload folder on an SD card, and using a specific button combination to initiate the update. One user noted that removing a magnetic case resolved the resetting issue, indicating that hardware factors may also contribute to the problem.
