12V to 230V Converter for Motorhome: Selecting Right Inverter for Blender & Rotary Washer
Mizioł 5784 4
  • #1 16290361
    Mizioł
    Hello, I need to use devices in my motorhome: a blender and a small rotary washing machine. Both devices 230v. Currently, I have a modified sine inverter but I have not connected the above devices to it.
    I have a question about the converter what is needed for these devices, because I have heard that some motors can work on a modified sine wave, and others not, but what and what it depends on, I do not know ...
  • #2 16290688
    PATAFIAN_PATAFIAN
    Conditionally unlocked
    Help: 38
    Rate: 54
    First of all, give the power of devices you want to connect to the inverter, battery capacity and, among others, the power of the current inverter.
  • #3 16290732
    Mizioł
    and how will this affect the sine wave I need?
    I do not ask about the power of the converter or the thickness of the cables or the capacity of the batteries,
    I am only interested in which type of motors I can handle the inverter with sine mod. and for what you need full sine.
  • #4 16290896
    sylwek84
    the modified sine can operate:
    - laptop, computer (without active pfc in the power supply)
    - power tools (e.g. angle grinder, drill) - that is, all commutator motors (speed regulators may not work properly, but they must not)
    - energy saving light bulbs
    Induction motors (e.g. water pumps, air conditioners, refrigerators) have a problem with work, will rumble and growl (it's about higher harmonics, such a charm of induction motors)
    Therefore, if the blender has a commutator motor, there will be no problem, and the washing machine has an induction motor, it is better to use a pure / full sine converter.
    Of course, you can not exceed the rated power of the inverter - there must be a spare.
  • #5 16291299
    Mizioł
    thanks for the comprehensive information, that's what I meant,
    best regards
