iPhone 6 Water Damage Recovery: Compass Restored, Spirit Level Calibration & Related Systems
5631 12
Which iPhone 6 sensor circuit controls the spirit level, and where should I look for a fault when the level reading drifts after water damage?
The spirit level is part of the InvenSense MPU-6700 6-axis gyro/accelerometer in area U2203, while the compass is the AKM compass in U1901; the iPhone 6 also uses a Bosch BMA280 accelerometer in U2205 and a Bosch pressure sensor in U2204 [#16297734][#16294379] In other words, the leveling/orientation function is not a single “calibration” item but a MEMS sensor set made from several ICs [#16297734][#16294976] The compass had to be retranslated/replaced before it worked again, which fits the thread’s conclusion that the remaining bad behavior is likely hardware-related rather than a software reset issue [#16297734] Since the level reads “0” when hot and drifts as it cools, the thread points toward a temperature-sensitive damaged sensor or soldering problem in that sensor section, especially around U2203/U2205/U2204 [#16297734][#16294841]
  • #1 16290411
  • #2 16292547
    jib
    Rate: 17
    And if the phone lies still, the wallpaper moves?
  • #3 16292596
  • #4 16292609
    jib
    Rate: 17
    Or the accelerometer is broken .... That's why I asked.
  • #5 16293083
  • #6 16294379
    RafalB
    Help: 91
    Rate: 222
    tojaert wrote:
    where to look for accelerator in Ip6?
    On the diagram? :D
    Overall, the iphone compass / accelerometer assembly has a total of 3 layouts :)
    - magnetic field sensor
    - accelerometer
    - 3-axis gyroscope with accelerator
    The pressure sensor is at the memory of nand, you can diagnose it by reading in the application :)
    iFixThis
    Łowmiańskiego 18, Poznań, 60-685 | Tel.: 516XXXXXX (Show) | Company Website: https://www.instagram.com/ifixthis.pl/
  • Correcting iPhone 6 sensor locations and axis counts
    #7 16294841
  • #8 16294976
    RafalB
    Help: 91
    Rate: 222
    tojaert wrote:
    the gyroscope is Bosch or InvenSense or / 3rd I don't remember / mounted in the U2203 field. In addition, 6 axis, not 3 axis as you write (6 axis gyro MP67B IC chip)
    You are right, my mistake! This system is probably even the so-called combos, i.e. gyro and accel in one, and yet there is a separate accelerometer system.
    Look for another pattern ;)
    Yes, as you have layouts from the discharge it sometimes behind the 10th system works, such a charm of the apple solution used (calibration?) I did not figure it out, the new systems work from scratch as long as the magnetic sensor is OK because it often does a problem in flooding.
    As for the application, it is based only on the tests of a friend, personally I never wanted to verify it and even better, now I do not do it, I know that this sensor only once did a problem.
    iFixThis
  • #9 16295793
  • #10 16296104
    RafalB
    Help: 91
    Rate: 222
    tojaert wrote:
    I see you don't know much, you cover your ignorance with colleagues. Sad.
    Should I look for an application in the appstore that reads sensors?
    Scheme should I look for you too?
    Not everyone has enough time to serve everything on the tray, I don't see the topic in the beginner section, so I assumed that all you need is to show the way.
    iFixThis
  • #11 16297734
  • #13 16297955
The discussion revolves around the recovery of an iPhone 6 that suffered water damage, specifically focusing on issues with the compass and spirit level functionalities. The user successfully restored the compass using a Bosch system but faced challenges with the spirit level, which displayed inaccurate readings. Participants suggested that the problem might stem from the accelerometer or gyroscope, both critical for the device's leveling systems. They discussed the layout of the iPhone's sensor systems, including the magnetic field sensor, accelerometer, and gyroscope, and the potential for damage to these components due to water exposure. The conversation also touched on the need for proper calibration and the importance of the pressure sensor in the context of the device's functionality. The user is awaiting parts to attempt further repairs.
