Can a Flooded iPhone 5s with Broken Speaker be Saved? Seeking Experiences with Water Damage
marika8686 5550 2
  • #1 16316257
    marika8686
    Hello all,
    today in the heat of fever a telephone fell into my bathtub. I pulled it out quickly. The telephone was working, you could hear someone calling, everything was great, only the speaker did not work - the caller could not be heard. I took the phone to the service. They were supposed to "bathe him" there. After 7 hours I went to pick up and you said you need to replace the tape. when turning the phone he said that the speaker did not work, connected a new speaker and said that there was some reverberation ... the phone was in service tomorrow - it should check if it has short circuits - as it is not profitable to replace the motherboard.
    please tell me if I can save my phone?
  • #2 16316530
    gsmowiec
    User under supervision
    Help: 27
    Rate: 128
    Nobody will tell you this without a diagnosis, especially after a flood.
    Tell this service technician that motherboards are also being repaired and not only replaced ...
    Try on another site.
  • #3 16317076
    venummasa
    Level 19  
    Help: 28
    Rate: 69
    After the flooding, someone mistook the order of cleaning first, then replacing, unless someone suggests (in this case the customer) "fell into the water but that everything works, please replace the speaker" which does not mean that during the day it may well stop completely turning on and then the disc can be replaced
