iPhone 6 Compass/Accelerometer Assembly Replacement: Possible or Not?
wlodek04 3999 3
  • #1 16402469
    wlodek04
    Rate: 10
    Compass and spirit level in iPhone 6 not working. Diagnosis: compass / accelerometer assembly damaged. So far, no service wants to undertake the exchange. They argue that this is almost impossible due to the microscopic dimensions of the components to be replaced. Can anyone on the forum advise?
  • #2 16403287
    marci4
    Help: 169
    Rate: 177
    But what kind of advice do you expect?
    If you want to ask if it can be done this way, it is possible. However, you must have the right tools and, above all, experience with repairing plates from iPhones.
    gsmowiec
    User under supervision
    Help: 27
    Rate: 128
    These systems are not that microscopic at all - just like the colleague mentioned above - a good hand and a good microscope are enough.
    Return to the service where they specialize in such repairs of phone motherboards, and not for those that only repair large motherboards.
  • #4 16473930
    wlodek04
    Rate: 10
    Problem solved. Sent to a professional site in Poznań. The fault has been removed.
