Asus K51A Laptop: No BIOS Screen, LED & DVD Drive Functioning, Processor Fan Not Working
bartekb24 3867 13
Why does my ASUS K51A power on with LEDs and DVD activity but show a black screen, with no BIOS image, no CPU fan spin, and no response to the power button hold?
The most likely fault is the motherboard/chipset, especially the northbridge/AMD M880G (RS880M) system chip, not the CPU. In this model the northbridge was identified as the main suspect, and CPU failure was described as very rare [#16293352][#16293411][#16295675] The usual checks are a CMOS/BIOS reset, testing with a known-good supported RAM module, and a diagnostic heat test; if the laptop shows an image only after warming up and restarting, that strongly points to a damaged northbridge [#16293411][#16293352] One reply also suggested checking/replacing the DC-in jack because the machine had intermittent power-on issues before the failure [#16295675] In the thread, the final outcome was that the motherboard was damaged [#16875954]
  • #1 16292730
    bartekb24
    Rate: 27
    I have an ASUS K51A laptop. Until Friday everything was working fine. On Saturday I wanted to start the computer and nothing even appears on the bios screen. The LED on the laptop is lit, so the power is on. DVD ejection also works.
    Hear the disc running and the DVD drive booting while turning on the laptop.
    I opened the laptop and tried to run it with only one RAM chip and no RAM and it makes no difference, still the same. I checked on a different power supply and there is exactly the same problem.
    I noticed that the processor fan does not turn on at all, and one more thing, if I want to turn off the laptop by holding the power button for a longer time, it does not turn off only after removing the plug.
    I also tried booting with the battery in and the effect was the same.
    What's the problem?
    I suspect a processor or motherboard.
    Would the computer's bios boot with a damaged processor?
    What do you think is damaged?
    Visually there are no swollen capacitors etc on the motherboard, everything looks normal?
    What else can I check and how to determine the cause of the failure?
  • #2 16292739
    kindlar
    Help: 919
    Rate: 1621
    Have you reset your bios to factory settings? Can you enter the bios and set boot from disc or pen?
  • #3 16292750
    bartekb24
    Rate: 27
    If you mean removing the battery then yes.
    As I wrote for the bios, I can not enter. Nothing appears at all any subtitles after starting just black screen immediately. So I can't change the settings to booting from a flash drive.
  • #5 16292769
    bartekb24
    Rate: 27
    In the case of the bridge, the motherboard to be replaced? In other words, buying a new laptop? :(
    Added after 2 [hours] 30 [minutes]:
    I have a friend who has an ASUS 70A.
    So I decided to check if it was not the processor's fault.
    I plugged in my CPU in his laptop and he only got a black screen.
    So I did a replacement on my laptop and connected its processor but still only had a black screen.
    I reconnected my friend's CPU to his laptop and surprisingly I have a black screen on his laptop as well as mine :(
    It is possible that I damaged my friend's CPU by connecting it to my laptop for up to 1 minute ?? :(
    Before the CPU swap, his laptop worked fine.
    Added after 13 [minutes]:
    Fortunately, after waiting for about 20 minutes, my friend's laptop booted up and works fine :)
    But why the problem arose I have no idea then.
  • #6 16293198
    przemob4
    Help: 5
    Rate: 20
    The bridge can be replaced, although it is not said to be damaged, do a cmos reset.
  • #7 16293294
    bartekb24
    Rate: 27
    I did the reset. Is it possible to check if it is a 100% bridge at home?
    You can replace the bridge, but the amount for the repair + no warranty on other parts in the laptop means that something may fall out again in some time, so I probably prefer to invest in a new laptop instead of adding to it. And the laptop is already years old, so the performance of components was not too good compared to new laptops.
  • #8 16293352
    sk1977
    IT specialist
    Help: 1326
    Rate: 742
    In this model, the northern bridge is the most suspect - its defect can be diagnosed, for example, with a socket tester.
    You can also leave the laptop turned on to heat up - then turn it off and on immediately - if you see an image, then 90% of your NB is damaged.
  • #9 16293411
    elessar87
    Help: 198
    Rate: 88
    Did you check the compatibility of the processors with both motherboards before replacing them? My friend's laptop did not start with your processor because the motherboard did not support it. The processor is an extremely rare failing computer component. Don't look for the reason there.
    If you gave the specification of the problematic equipment or at least the full model designation, it would be easier to say anything.
    If it's a computer with an ATI / AMD chipset / graphics chip, you probably have the chip blown.
    Sequence of actions:
    1. BIOS reset,
    2. Substitution of 100% efficient (and supported) RAM module,
    3. Diagnostic heating of a suspect system.
    Although I do not advise you to do the latter if you approach diagnostics with such ignorance.
  • #10 16293654
    lisek
    Service technician RTV
    Help: 6350
    Rate: 6880
    Provide descriptions from the motherboard something like
    e.g.
    asus k51A
    mb: k51ab rev: 2.1
    specify: whether AMD platform, cpu type, chipset,
    In this forum, Fr.
    Phrase: Asus K51A Found 504 results (0.45 s)
  • #11 16293764
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    bartekb24 wrote:
    so I guess I'd rather invest in a new laptop instead of adding to that. And the laptop is already years old, so the performance of components was not too good compared to new laptops.
    The right decision is a very emergency album.
  • #12 16295581
    bartekb24
    Rate: 27
    MB Ver to K51AE ID: 1A
    AMD M880G chipset (RS880MN)
    I checked on a friend's laptop because it is basically the same model, only larger, i.e. Asus K70AE, so the processor should approach. And one more information, for about half a year or more in the laptop, after connecting the power supply, it was sometimes impossible to turn it on, as if the power was not supplied. Only pulling out and reinserting the plug into the laptop helped. It happened once a week, say. I don't know if it has any importance in the diagnosis.
    Added after 16 [minutes]:
    I checked on a different RAM and it's the same
  • #13 16295675
    lisek
    Help: 6350
    Rate: 6880
    in the laptop, after connecting the ac power adapter, it could not be turned on sometimes, as if the power was not supplied. Only pulling out and reinserting the plug into the laptop helped.
    Start by replacing the DC-in plug
    Then pass it what chip do you have in charger _power switch?
    - from the BQ24xxx or ISLxxxx or MB39A132 series?
    There is no SM under K51AB Rev2.3
    MB Ver: K50AF ID: 1A
    MB: Asus K51AB Rev: 2.3
    KBC: ITE IT8500E BXA
    chipset 216-0752001 (RS880M 14+)
    Typical in this series is ... North epilepsy, i.e. heating with Hotem helped for ... some time.
    * K40AA or K40AB
    Your zcasu on this forum Link
    ________________________________________
    Chipset (AMD M880G) supports
    Mobile Phenom II,
    Mobile Turion II,
    Mobile Athlon II,
    Mobile Sempron
    DDR-II PC2-6400 (800 MHz)
  • #14 16875954
    bartekb24
    Rate: 27
    I gave my laptop to the service. The motherboard was damaged.
The ASUS K51A laptop is experiencing a failure to display the BIOS screen upon startup, despite the power LED and DVD drive functioning. The processor fan is not operational, and the laptop does not respond to power button presses for shutdown, requiring unplugging. Initial troubleshooting included testing with different RAM and power supplies, but the issue persisted. Users suspect a motherboard or processor failure, particularly the northbridge component, which is known to cause such symptoms. Suggestions include performing a CMOS reset, checking processor compatibility, and diagnosing the northbridge with a socket tester or heating method. Ultimately, the motherboard was confirmed to be damaged after professional assessment.
