How to connect two routers ?? - I have a router with a Wi-Fi IDU-200 plus.
Dudis44 4533 5
  • #1 16294235
    Dudis44
    I have a router with a Wi-Fi IDU-200 plus. I would like to wirelessly connect to a second router to increase the range. What router to buy? And how to configure?
  • #2 16294250
    any56
    Help: 656
    Rate: 840
    I suggest you buy a WiFi repeater.
    Simple and much cheaper ...
  • #3 16294273
    Dudis44
    But from the second router it needs to connect to the decoder with a cable. And the main router downstairs so the cable comes off directly.
  • #4 16294783
    matek451
    Help: 4352
    Rate: 5808
    Measure the signal level from the IDU in the location of this AP Client, the minimum is -70dBm for the wireless bridge to work. Use WiFi Analyzer for Android or inSSIDer. The additional AP is to provide connection only via cable or further via WiFi?
  • #5 16296952
    Dudis44
    You only need to use the cable.
