Extending Wi-Fi Signal with Second Router: TPLINK WR841N & Airlive G Duo, WDS+AP, Gateway+AP Modes
dupti 6117 6
  • #1 16817583
    dupti
    I have problems with the Internet. I rent a room and it so happens that the router (TPLINK WR841N) is at the other end of the apartment and you can't move it. The signal is consistently weak, but there is still enough for everything (YouTube, online games). However, sometimes (in the evening, I think everybody uses the internet at the time and that's why) it starts hanging down terribly Ping in online games, video on YT takes a long time to load. Everything is starting to hang. At such moments I took a laptop and went inside the apartment and all problems disappeared and everything began to work normally. As I understand it, the reason is a weak signal.
    I have a second router (airlive g Duo) and I want to use it to strengthen the signal, set the router in the center of the apartment, there are several modes:
    WISP + AP mode
    Client + AP mode
    Dual AP mode
    Gateway + AP
    WDS + AP
    Not quite knowing which is better, I tried to use the WDS + AP mode and it did not work, and then the WISP + AP mode and I did it, at first it seemed that everything was done but when I started testing, the signal definitely stopped better because the other router is closer, but in fact, when I start to download something, the speed decreases and the ping increases (performed in the console "ping google.com -t" ;) .
    My testing file download speed:
    through the main router in my room (WiFi) - 3.5mbps, ping - 100-200ms
    through the main router in the middle of the apartment (WiFi) - 5mb / s, ping - 100-200ms
    through the second router in the middle of the apartment (WiFi) - 300kb / s, ping - 500-3000ms
    through the second router in the middle of the apartment (cable) - 1.2mbps, ping - 200-500ms
    What is the reason? How can I solve my problem?
  • #2 16817623
    roxio
    Help: 108
    Rate: 213
    Plug in in client + ap mode, you should have delays of 10-20ms between devices. Do not expect miracles, the more users currently use the network, the greater the pings, remember that the router to which "everyone" is connected automatically prioritizes data packets, you would have to set QoS rules on this main device, restrict other transfers or redirect specific game ports online directly to your address.
  • #3 16818100
    dupti
    @roxio , I did in client + ap mode, it's exactly the same as wisp + ap, i.e. I have
    I don't expect miracles, but now it's because of this second ping router and the download speed is worse than if I just used the main router and I just want to have better coverage and I can accept even lower speed, I just need stable ping because I play in game, I talk to someone and all this requires a stable connection.
  • #4 16818190
    KOCUREK1970
    Help: 3867
    Rate: 5500
    dupti wrote:
    What is the reason?
    The amplifier is the worst solution.
    Connect wired to the main router and then do an additional AP.
    To have something to strengthen, you need to have a stable and reliable signal in place of the repeater.
    Install InSSIDera v2 / Home and insert the network measurement result here.
  • #5 16818325
    dupti
    @ KOCUREK1970 , unfortunately it is not possible to connect to the main router via cable, I have access to the admin panel, but unfortunately I cannot move the router and connect via cable.
    • Extending Wi-Fi Signal with Second Router: TPLINK WR841N & Airlive G Duo, WDS+AP, Gateway+AP Modes z.png (9.23 KB) You must be logged in to download this attachment.
    • Extending Wi-Fi Signal with Second Router: TPLINK WR841N & Airlive G Duo, WDS+AP, Gateway+AP Modes x.PNG (66.8 KB) You must be logged in to download this attachment.
    • Extending Wi-Fi Signal with Second Router: TPLINK WR841N & Airlive G Duo, WDS+AP, Gateway+AP Modes c.PNG (73.32 KB) You must be logged in to download this attachment.
  • #6 16818334
    KOCUREK1970
    Help: 3867
    Rate: 5500
    Only that the signal from TP Link should be measured in the place of placing the amplifier - and you probably measured yourself?
    The first of you with Duo is ok, the second DNO.
  • #7 16820141
    geniusm
    Help: 70
    Rate: 49
    You don't have anything other than this airlive? Something from 802.11n? Once that speed 3 x greater two that better range. If ok in the middle of the apartment on the laptop, then properly configured and connected router must also work properly.
The discussion revolves around extending Wi-Fi coverage using a second router, specifically the TPLINK WR841N and Airlive G Duo. The user experiences weak internet signals due to the distance from the main router, leading to high ping and slow speeds during peak usage times. Various modes for the second router are considered, including WISP + AP, Client + AP, Dual AP, Gateway + AP, and WDS + AP. Recommendations include using Client + AP mode for better performance, though results vary with reported speeds and ping issues. Some participants suggest that a wired connection to the main router would yield better results, but the user is unable to do so. The importance of measuring the signal strength at the amplifier's location is emphasized, along with the potential benefits of using a router that supports 802.11n for improved speed and range.
