Second Router or Replacement for IDU 200 to Improve LTE Internet Coverage in Cyfrowy Polsat Home
Nedvied 8274 8
  • Using a second router as a wired access point
    #1 16853272
    Nedvied
    Hello. I have LTE internet in Cyfrowy Polsat. I have equipment from them in the form of an idu200 router and an external odu200 antenna. Unfortunately, the idu200 on the first floor does not wirelessly cover the ground floor of the house. I am considering buying another router that I would use instead of the idu200 or the other one that I would connect to the odu200 with a cable and place it on the ground floor to distribute the signal wirelessly. Are such options possible at all? If so, I am inclined to the second solution only what, with what and how ... Thanks in advance for all the help.
  • Configure a second router as access point via LAN-LAN
    #2 16853312
    matek451
    Help: 4356
    Rate: 5815
    After all, the IDU has to stay because it supports the ODU. Buy a router for it and set it as AP. You connect it with a LAN-LAN cable to the IDU and then you have one network in your home created by the IDU. On the router, you set the address 192.168.0.2, you turn off the DHCP server, the WiFi network has the same name or a different name, the encryption is the same as an IDU, the WiFi channel is different. On the IDU you set the DHCP to the range 192.168.0.10-192.168.0.100. The cheapest router is for example WR-841. How does Plus LTE work on this set, what speeds, signal parameters, what LTE band do you use?
  • Request for a stronger router than the TP-Link
    #3 16853347
    Nedvied
    Thanks for the answer. I called the CP technical department and they were unable to give me a specific answer there. Previously I had idu100 and odu100. It was a tragedy. Now there is no madness either, but compared to that, it is day to night. The transfer rate increased several times to around 10/3. Previously, downloads were around 2mb / s and less. There were a dozen at night. Of course, now I work in the 2600 band. Previously it was 800. Can you recommend something stronger than the given tp link?
    KOCUREK1970
    Help: 3863
    Rate: 5495
    What for - the link you have is poor and this one is enough.
  • Poor LTE2600 signal likely limits speed
    #5 16853640
    matek451
    Help: 4356
    Rate: 5815
    Got 10/3 Mbps on LTE2600? What is the location, such poverty indicates the poor parameters of the LTE2600 signal on this ODU200. Show the signal parameters from LTE Status to IDU. Of course, the WR-841 is enough for these speeds. In Play, I have DL 100-200Mb / s and I use TOTOLINKA AC3002RU as an additional AP, i.e. a router with WiFi in AC1200 with Gigabit LAN connected to the E5186, which has the same ports and it makes sense. Your IDU has 100Mb / s ports and there is no point in buying a better AP router for it.
  • #6 16857285
    Nedvied
    The town of Strzelno province. kuj-pom. The distance from the transmitter is about 1.5-2 km.
    LTE status
    Connection status Connected
    USIM Status Ready
    IMEI ------------
    IMSI ------------
    RSRP -112 dBm
    RSRQ -11 dB
    RSSI -93 dBm
    SINR 2 dB
    Location information 38
    Band 7 (2600 MHz)
  • #7 16857312
    m.jastrzebski
    Help: 679
    Rate: 865
    LTE status
    USIM Status Ready
    IMEI ------------
    IMSI ------------
    RSRP -112 dBm -83
    RSRQ -11 dB -11
    RSSI -93 dBm -60
    SINR 2 dB 11
    Band 7 (2600 MHz)
    What a crap. I have a similar distance as you with a cane on the way but, normal antenna and router in the same box as the antenna (no antenna cables). My parameters highlighted. What you give must be eminently idiotic.
  • #8 16857394
    matek451
    Help: 4356
    Rate: 5815
    And on BTS Strzelno 44119 does LTE2600 Plus work at all? Check the CP card and LTE phone with the Network Cell Info application, it will show BTS eNB, ECI and signal parameters. Test at home and under the BTS. And the signal parameters are tragic for 1.5 km from the BTS on this ODU, but it's normal for this invention. There are cheesy omnidirectional antennas with practically zero gain in ODU.
  • #9 16857425
    Nedvied
    On the 800mhz and 1800mhz bands the DL and UL values are somewhere around 2/1. What do you propose in this case? Any modification of the ODU200 or the purchase of something specific?
    Added after 13 [minutes]:
    LTE parameters
    • Second Router or Replacement for IDU 200 to Improve LTE Internet Coverage in Cyfrowy Polsat Home Screenshot_2017-11-29-19-55-28.png (546.71 KB) You must be logged in to download this attachment.
The discussion revolves around improving LTE internet coverage in a home using Cyfrowy Polsat's IDU200 router and ODU200 antenna. The user seeks advice on whether to replace the IDU200 or add a second router connected via LAN to enhance wireless coverage on the ground floor. Recommendations include using a TP-Link WR-841 as an additional access point (AP) connected to the IDU200, with specific settings for IP address, DHCP, and WiFi configuration. Users also discuss signal quality issues, with parameters indicating poor LTE performance at a distance of 1.5-2 km from the transmitter. Suggestions for alternative solutions include checking the signal parameters and considering modifications to the ODU200 or purchasing a more effective antenna.
